pulled the plugs yesterday...
Old Sep 18, 2006 | 12:05 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
and they were all white.... so that means i need fuel..... i was pretty damn sure that the stock injectors would hold up to this power but i guess not.... so i think i am going to change injectors out to some 22lbs.....
Old Sep 18, 2006 | 02:09 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
what about a AFPR? Just turn the fuel pressure up
Old Sep 18, 2006 | 06:43 PM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
Old Sep 18, 2006 | 10:41 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
already have one... up to 43 psi...
Old Sep 18, 2006 | 11:51 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
42 psi is stock so you can go up to 48 or 50
Old Sep 19, 2006 | 10:38 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
really.... hmmmm might have to try that....... well i bumped it up before but really didn't notice much.....
Old Sep 20, 2006 | 09:53 AM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
could you be using plugs that are too hot?
Old Sep 20, 2006 | 10:52 AM
Damon's Avatar
You won't. It's not like it makes a "holy cow" kind of difference in injector flow. Besides, your O2 will pull the part throttle mixture back to stoich anyway. And FYI, your plugs will always look clean as a whistle if you're just idling and driving normally becuase you're spending much of that time in closed-loop operation with the O2 keeping things in check.
You might want to drive around with a scan tool attached and see where your blocks learns stabilize at. Around 128 and you're about right on the injector flow. Low and you're rich. High and you're lean.
Old Sep 20, 2006 | 08:03 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
i do have an air fuel gauge and it stays in the red or a little in the yellow....
Old Oct 1, 2006 | 08:38 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
i fixed it!!!!!!!!! i had relocated the air intake temp sensor to the air box a long time ago and i striped some wire back and it was grounding out..... runs a little rich now..... oh well i'm going to spray it.... 75 wet shot....
Infested
May 22, 2018 11:56 PM
Bert87
Aug 23, 2015 03:50 PM
mdtoren
Aug 23, 2015 12:52 PM
GouldyGTR
Aug 21, 2015 10:43 PM
mdtoren
Aug 16, 2015 05:45 PM
