oil on the intake means...?
Old Sep 21, 2006 | 02:11 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
which seal/gasket is bad? i'm about to pull the intake on a recently rebuilt 5.7 TPI engine because of oil "consumption" and in the process of tearing down, discovered oil pooled up on the driver side between #3 and #5 runner. didn't see any on the pass side. had this same problem years ago when it was still under warranty, and believe it to have been the intake gasket. regardless, i'm sucking down a qt of oil every 500 miles or so. supposedly a bad intake gasket there, too. so before i go all the way down to the intake, looking for clarification... plugs are coking up from it and i hate to think what my new innards look like now because of this. which brings up another ? - what can be used to clean the engine now in hopes to at least somewhat remove all the crap i'm thinking is in it now. i'm down to one runner and the intake left to remove, but probably a better idea to get another opinion at the moment. the gasket used on the rebuild was a stock GM gasket, same as the one i used a few years back. anyhow, i'm hoping both issues are due to the same gasket...
Old Sep 21, 2006 | 03:48 PM
Guest
Guest
Posts: n/a
Between #3 and #5, sounds like sealer was not used on the intake manifold bolts.
I doubt the oil consumption is related to a leaky intake unless its always been using that much oil.
Old Sep 21, 2006 | 07:09 PM
Car: '91 Z28
Axle/Gears: 323's
sealer was used on all the bolts... and since the rebuild, yes, it has always been using that much oil. almost found that out the hard way. machine shop seems to think it's a bad intake gasket and sucking it in to the cylinder(s).
Old Sep 21, 2006 | 07:57 PM
gotay's Avatar
oil
oil in the intake bad pvc valve
Old Sep 22, 2006 | 08:45 AM
Car: '91 Z28
Axle/Gears: 323's
interesting. so much for those new parts, huh? i'll change that, too. thanks.
Old Sep 24, 2006 | 07:31 PM
Kranberry's Avatar
Car: 1989 Firebird Formula
Engine: L98 350 ci TPI
Transmission: Automatic
What sort of symptoms would I experience if my intake manifold had a leak? How would the car be running? 1989 Formula 350
Old Sep 24, 2006 | 07:59 PM
Car: '91 Z28
Axle/Gears: 323's
well in my case, mine ran fine til the plugs got all fouled up from the oil being sucked in to it. but what kind of leak are YOU talking about? oil? vacuum? water? when i got my intake off, i could see oil residue up the side of the heads where they meet the intake, more so between #3 and #5. i had used GM gaskets on the build, which is the same as i used last time with no problems. they are a crush-type seal gasket... this time i put a thin film around all the ports and bolt holes, so should be good to go. i'll find out in a few days when the rest of my stuff gets here...
Old Sep 25, 2006 | 06:32 PM
Kranberry's Avatar
intake manifold
I'm thinking vaccum leak.
Old Sep 26, 2006 | 08:57 AM
Car: '91 Z28
Axle/Gears: 323's
yea, that'll cause some run-ability problems...
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
