Fuel lines
Old Oct 8, 2006 | 07:40 AM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
Fuel lines
Will the steel fuel lines on my lg4 camaro work with the tpi setup I'm putting on? Will I be able to just get High pressure lines from there to the fuel rails?
Old Oct 9, 2006 | 07:20 AM
Engine: 5.3L
Axle/Gears: 3.42LSD
bump
Old Oct 10, 2006 | 12:42 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
bump
Old Oct 10, 2006 | 03:36 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
I need some info on this soon. I plan on cranking my new motor within 2 1/2 weeks. HELP!!!
Old Oct 10, 2006 | 03:51 PM
Abubaca's Avatar
Well I'm not 100% positive, but as far as I know, as long as you have a new pump capable of flowing enough fuel, the lines, assuming they're not old school runner lines, should be fine.
Old Oct 11, 2006 | 12:37 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
I'm gonna buy a new pump to flow at least 45 psi. I just notice everone talking about changing the fuel lines out from tank to fuel rails if car came stock with carb. I figure why do that if you can use the lines that are there. Is there a certain size line needed to run with the high pressure pump? What do you mean by old school runner lines?
Old Oct 12, 2006 | 09:58 AM
Abubaca's Avatar
oops, I meant "rubber" lines!!!!
...I think that's what people mean when they say you can't re-use the fuel lines from a carbed car. If your lines are steel/metal and not rubber, then I don't see why you can't use 'em....
....but I'm not the expert, so I'd double check it.
Old Oct 12, 2006 | 12:27 PM
Drac0nic's Avatar
Steel lines should be fine, any rubber you have should be replaced. I thought carbed cars didn't have a return line though.
Old Oct 12, 2006 | 03:30 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
I think it might be some rubber from the tank to the lines on the body. What kind of lines should I use to replace these?
Old Oct 12, 2006 | 04:01 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Lines
Parts store.
Rubber- Hi pressure- gas approved lines, 3/8.
Could be 5/16 but I used 3/8 and double clamps.
In that short a span don't know if Hi pressure lines
needed but pays to be safe.
Later
Irocing
Old Oct 12, 2006 | 10:06 PM
Abubaca's Avatar
I just did a search on "fuel lines".
Not that I doubted JayKar, but apparently several people have used rubber hi-pressure lines with no problems.
Hope that helps.
Old Oct 12, 2006 | 11:26 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
Thanks for all the help you guys have provided me. Will I have to drop the tank to change the rubber lines from the tank to the frame?
Old Oct 14, 2006 | 08:47 PM
Pat Hall's Avatar
One of the best places to score fuel lines that'll work with a tpi setup is from one of the fuel injected V6 f-bodies, which are all over the place in most junkyards. The V6 multi-port fuel injection on the 2.8 and the 3.1 engines required the same high fuel pressure as the V8 tuned port cars, so the fuel lines are virtually identical. Those cars are your best bet for finding the correct fuel lines easily and for a cheap price to boot.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
