zz9 cam and only 9inchs of vac
Old Dec 20, 2006 | 09:44 PM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
hi all im having a problem with my pcv not working right. my zz9 cam is only letting me pull 9inchs of vac and i belive my pcv is not opening up at idle from the lack of vac. my pass side valve cover has a breather on it cause the the hose that runs from it to the tb keeps getting clogged with oil and gunking my tb.
anyway im tired of smelling all the oil vapors inside my car at a every stop from the the vapors making its way to the cowl is there a way to fix this problem do they make a pcv vavle that opens at such a low vac???
much thx if u can figure this out for me
Old Dec 20, 2006 | 09:50 PM
brutalform's Avatar
The breather is your problem. I would put the stock breather, and PCV system back the way it was. MAF cars do not handle air leaks besides the PCV valve too kindly.
Does you valve covers have the correct baffles under them? If not, that may explain the oil coming through.
I doubt it is the cam. I used to run a ZZ9 cam in my old 355, and never had a low vacuum problem.
Also, I PMed you.
Old Dec 21, 2006 | 02:34 AM
3.492rs's Avatar
Car: 89 IROCZ
but if i put the pass side stock breather tube on, the oil vapors get into my tb and gunk it up cause the pcv won't open at idle.
on the vac side of things, i pulled 9 inchs of vac on my old zz4 cam also the only time everything (ie brakes and pcv) worked right is when it still had the stock l98 cam.
Old Dec 21, 2006 | 05:58 AM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
There is something else wrong with your car. The ZZ-9 cam should pull at least 15" of vacuum at idle. I used to run the zz-9 cam and it idled very smooth at 750 RPM with 15+" of vacuum. My current cam is the ZZ-409 and it still idles with 13" of vacuum at 800 RPM.
I would check your timing, idle RPM, and hook up the stock breather. If the system is working as designed the stock breather will allow clean filtered air into the engine at high vacuum when the PCV is drawing vapor out. The breather will allow vapor out at low vacuum (WOT) conditions and allow it to enter the throttle body and be burned.
Old Dec 21, 2006 | 07:15 AM
Vader's Avatar
Including valve timing. You may need to check with a degree wheel to make sure you didn't get one of "those" cams or timing sprockets.
Old Dec 21, 2006 | 01:57 PM
3.492rs's Avatar
Car: 89 IROCZ
ok my timing is at 4* i think stock is 6* but will that really matter?? im putting the stock breather back on again.
anything else u think i could do also?
Old Dec 21, 2006 | 02:58 PM
brutalform's Avatar
Would not be the first time a TPIS cam was "off a bit".
Old Dec 21, 2006 | 03:20 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
When you check your timing make sure the timing advance connector (mounted on the firewall) is disconected.
Old Dec 21, 2006 | 08:45 PM
3.492rs's Avatar
Car: 89 IROCZ
it is, i know how to set base timming
Old Dec 21, 2006 | 09:11 PM
3.492rs's Avatar
Car: 89 IROCZ
but my old zz4 cam had 9inchs of vac also, they can't both be bad cams. im jealous u guys are getting 15inchs of vac with ur zz9's, getting tired of my brakes not working properly
pjsparts
Oct 29, 2025 06:39 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
rjcme
Sep 5, 2015 01:23 PM
Strick1
Sep 4, 2015 07:11 AM
