Question On Throttle Bodies
Old Jan 23, 2007 | 02:54 AM
rock861261's Avatar
Quick Question i have a stock 91 350 camaro if i get a 58mm throttle body will i see a difference in horsepower? or is it to big for stock
Old Jan 23, 2007 | 03:37 AM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Thatd be a waste of $ on a stock car. Start with (headers/y pipe) exhaust and CAI.
Until youve got H/C the stock tb really isnt restrictive . (ram jet 502's run 48mm twin bore tb's...)
Old Jan 23, 2007 | 07:16 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
a 58mm throttle body will do nothing but hurt your bottom end.
Rather then get a 58mm throttle body, go for a Airfoil in the stock 48mm. Adds an extra 50cfm of air flow. (would be about 850cfm).
Theres no way you need anymore then that if you are using the stock TPI set up, as you are limited by runners/base/plenum flow.
Hope this helps,
Sheldon
Old Jan 23, 2007 | 08:15 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Before you worry about getting more air INTO the engine, you should make sure you can get more air OUT.
As I understand it, a rock stock engine cant USE the additional air from a larger TB, because it technically cant use all the air it can get from the 48mm.
Now, if you intend on doing a whole slew of modifications and such, so that someday the engine will be able to use the additional air...sure...why not...
Old Jan 23, 2007 | 10:02 PM
rock861261's Avatar
well i can get a good deal on one 100 bucks but i have to trade my stock one and was seeing if it was worth it
Old Jan 23, 2007 | 10:08 PM
Abubaca's Avatar
Nope. Not worth it.
Old Jan 23, 2007 | 10:59 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
It is too big for the stock plenum. You would have to remove the plenum and hog it out so that the air passages would line up.
Old Jan 23, 2007 | 11:45 PM
Guest
Guest
Posts: n/a
Just because the ram jet 502 has a 48mm TB doesnt mean it wouldnt do better with something else. But on a 350, likely a waste until you've done quite a bit to the engine.
Old Mar 24, 2007 | 01:31 AM
piratagt's Avatar
Car: 1991 Chevrolet Camaro
Engine: 5.7l TPI
Transmission: 700
Re: Question On Throttle Bodies
i have a 1991 Z28 5.7l TPI
already got instaled
dynomax headers don't now the size
2 1/2" tube with "Y" pipe
and flowmaster
a set of stock heads ported
MSD ingnition Coil
8.8 Accel spark plug wires
iridium spark plugs
how mouch and air foil help in my setup , or be better to get a new TB??
Old Mar 24, 2007 | 02:42 AM
Abubaca's Avatar
With the modifications you have, neither will do a whole lot. If you put your car on a dyno, or ran it at the track, you may possibly see a minimal difference, but I doubt you'll really be able to feel any difference.
Old Mar 24, 2007 | 10:17 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Sheldon
I was under the impression that a stock 48mm tb flows 630 cfm.
Old Mar 26, 2007 | 10:56 PM
piratagt's Avatar
Engine: 5.7l TPI
Transmission: 700
wha't do you recomend me to my set up
new intake manifold ?
modified prom?
the car also has
auto 700 transmission with B&M Shift Kit
and 3.27
what you think??
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
