The truth about Airfoils.
Old Jan 25, 2007 | 11:33 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
I just thought I would toss this out in the open.
http://www.ws6.com/mod-4.htm
Dyno charts of airfoils. Expect a 2 HP gain.
Old Jan 25, 2007 | 11:38 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I would think the higher the horsepower the motor was making the more the airfoil would be worth.
Old Jan 25, 2007 | 11:48 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
I would not think so much the more horsepower, but the volume. So lets say supercharger or turbo this would or could be a beneficial tool. Just like 58 mm TB's only good if you need it :P
Old Jan 25, 2007 | 11:53 PM
formul8!!'s Avatar
Car: 2004 GTO
Every little bit helps!!
All I noticed was a little bit better throttle response but no real SOTP benefit.
Old Jan 26, 2007 | 09:23 AM
Vader's Avatar
You could run that ten times on the dyno, and five times it would make more power, five times it would make less power. Which two (worst and best) runs do you think advertisers are going to use to market the product?
2HP MAYBE is different than almost 10 HP proven by simply changing to synthetic lubricants. That doesn't even begin to address the other benefits of using synthetics.
Decent valve springs (and no other mods) will probably get that much more peak HP over a stock engine, and you can get valve springs for $50.00 any number of places.
ULTM8Z
Sep 16, 2015 09:15 AM
CODY BEHNKE
Theoretical and Street Racing
Jan 29, 2002 01:40 PM
buddman91rs
Oct 30, 2001 10:15 AM
Blue5.71LE
Mar 2, 2001 03:24 PM
Baron
Jan 13, 2001 11:38 PM
