air intake
Old Jan 26, 2007 | 11:20 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
air intake
how does your guys air intakes look like on our tpi motors, im trying to find an elbow that will work with my application but i still havent been able to find anything that will work yet
Old Jan 27, 2007 | 12:50 AM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
All from the plumbing section of Lowes lol
Old Jan 27, 2007 | 07:59 AM
Car: 87 trans am
lol nothing, whatever works right! mine is from home depot, but i could never find anything like that big black elbow that you have. i mainly just need something to make the turn. i even thought about going with an lt1 intake elbow but the bad thing about them is that there is a bung welded into it for the sensor that we dont use on the tpi.
ANY OTHER PICS FROM YOUR INTAKES WOULD BE GREAT! get the ideas flowing
Old Jan 27, 2007 | 03:20 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
That elbow I am using is just a 90" PVC Elbow, the piece that attaches to the TPI itself is a 4x3 Reducer, ALL of the connections have rubber downspout connectors covering them with hose clamps....so no air can get out.
All that cost me under 15$
Old Jan 27, 2007 | 11:54 PM
wulff's Avatar
Car: 1987 Monte Carlo SS
Engine: 406 TPI
Transmission: T56 6-speed
That looks good quisterio! Is the elbow 4" (on the ends)?
Old Jan 28, 2007 | 01:32 AM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Yeah, pretty sure it is, the filter end has a 45" elbow, and the other is a 90", both 3.75-4 inches
Old Jan 30, 2007 | 10:45 PM
gunner53227's Avatar
Car: 86 TRANS AM
Transmission: 700 R4
Axle/Gears: 10 bolt/3.73
Did you notice a fair amount of increase of horsepower after that?
Old Jan 30, 2007 | 10:51 PM
Andy 91GTA's Avatar
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
You could check out http://www.intakehoses.com for a few things you will probably need.
Old Jan 30, 2007 | 11:51 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
I have no real numbers to back it up, but as soon as the car was started for the 1st time with it on, there was a Noticably louder sucking sound from the filter itself....more air..yay!
That, and I definately noticed throttle response went up, thats a fact, and as I said, I have no real numbers, but I can definately feel a seat of the pants difference at higher speeds...
Old Jan 31, 2007 | 12:13 AM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
Do you have an air foil? I only ask because it looks like it wouldnt stay in place if you did
Old Jan 31, 2007 | 01:20 AM
Demon355's Avatar
I ran the same setup quisterio has and I noticed the same things he did. Mine sounded like a small supercharger . I also used an airfoil. I planned on using my front foglight hole as a ram air duct and putting the filter under the charcoal canister plate so that it gets pure air and not air from under the hood.
Old Jan 31, 2007 | 03:54 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
yes, ive got a screw in air-foil, not a clip in one
Old Oct 26, 2007 | 04:00 PM
strider681's Avatar
Car: '87 Pontiac Trans Am GTA
Engine: 350 5.7L TPI (L98)
Re: air intake
I really need to make me one of those, think you can give a bill of materials or parts list of what you used? my stock duct work is cracking and i'm not passing emissions so i really wanna do this before I spend over $100 on a pre-made one! thanks in advance.
Old Oct 27, 2007 | 12:22 AM
strider681's Avatar
Re: air intake
I have a question about your intake setup.. how did you get the 4X3 reducer to fit around the throttle body? the TB is oval and the reducer is round, seems like you'd have to clamp it down really hard to make it oval and to seal properly.
Old Oct 27, 2007 | 01:43 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: air intake
i had a spare reducer like that layer around and the other day for hahas i was just messing around seeing what i could do for an intake and you just crush it to an oval shape them put it on and clamp it down im pretty sure it was sealed tightly too.
Old Jan 22, 2008 | 04:03 AM
Nifelheim's Avatar
Re: air intake
@quisterio... nice job on that intake dude. I've been meaning to do a custom job on my 93 LT1 something along those lines... the guy I bought it from put a crappy ebay CAI on it that doesn't really sit where I'd like it to. Eventually I plan to do ram air, but as a cheap alternative for the moment (so I can invest in better bang for the buck upgrades), I wanna take some silicone piping down under my driver's side headlight, pop out that useless black plastic panel and stick a K&N cone filter down there so it gets air directly blown into it. Your piping has inspired some ideas
Old Mar 13, 2008 | 12:09 AM
Badazz85TA's Avatar
Car: 1985 Trans Am
Transmission: 700R4 Automatic
Re: air intake
I've been using this thread for reference and thought i'd show what i've done to my T/A.
I basically did the same setup as quisterio, but went a couple steps further.
I cut a whole in my battery tray, put a 90 elbow underneath it and attached the filter down under so i can get cooler air, instead of that hot air in the engine bay. I've noticed a difference when the motor is hot and during warm days, the car revs up faster and she can breathe
in addition, i left the flap underneath the nose open to create a lil ram air effect:
Total cost: $61
Hope this helps anybody interested in making their own cold air intake. :-)
Old Mar 13, 2008 | 12:16 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: air intake
I have the same setup as Badazz85TA, I agree that having it behind the foglight gets PLENTY of COLD air...
Old Jan 18, 2010 | 10:26 PM
Three Arches's Avatar
Car: 1985 Trans Am
Re: air intake
Re an elbow for air intake, I picked up a length of flexible hose by Spectre at Kragen's, hooked it to the tpi intake, easy fit, and directly connected the other end to the existing intake hose. I removed the box and brackets. It was a simple operation, and I noticed an immediate difference in performance. Total cost around $30.00. Havent yet messed with the air cleaner canister, but that is coming next. Undecided about the oiled cotton filtration media, however.
Old Jan 19, 2010 | 03:35 PM
HCR13's Avatar
Car: 1987 Trans Am
Re: air intake
welcome to the board, I prefer the oiled media because "wet" material usually attracts more dirt particles and such... this thread is kind of old and I am no longer using this settup...
Old Jan 21, 2010 | 12:24 AM
Car: 1985 Trans Am
Re: air intake
Thanks HCR13, what setup are you using now for your custom cai?
Old Jan 21, 2010 | 11:25 AM
HCR13's Avatar
Car: 1987 Trans Am
Re: air intake
this is what I'm running now...
Old Jan 21, 2010 | 11:39 AM
vortecfiero's Avatar
Re: air intake
I had the same dilemma since my throttle body is similar to a TPI set up
had these already searched out...
http://www.jegs.com/i/Vortech/933/4G...oductId=760500
http://www.jegs.com/i/Granatelli/467...oductId=761116
http://www.jagsthatrun.com/Pages/Par...n_Ducting.html
ended up welding an aluminum one to my IC
Old Jan 23, 2010 | 07:34 AM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
Re: air intake
mines not worthy of pics. duck tapped the k/n cone the plenum. pretty ghetoo for now
Old Jan 23, 2010 | 11:31 AM
HCR13's Avatar
Car: 1987 Trans Am
Re: air intake
@vortecfiero
Thats pretty cool. Got any links to pics to your car? I have never heard of swapping a Syclone engine into a Fiero...
Old Jan 23, 2010 | 02:23 PM
Re: air intake
Originally Posted by HCR13
@vortecfiero
Ive helped do a couple of V8s, did a little work in a northstar and helped out
on a few SC3800s... I wanted the 4.3 because it was a code W CPI
200 hp 260 ftlbs naturally aspirated and i just knew i was going to boost it.
there are about 4 4.3 fieros runing around but i believe mine is the only one
with boost
using the Syclone intake, ecm, and injectors etc was a natural choice since
moats adapters and lots of tuning soft wear available for this setup the boost
control is awsum btw.
link to my build thread
http://www.syty.net/forums/showthread.php?t=63564
Old Jan 30, 2010 | 12:42 AM
tonymemphis's Avatar
Re: air intake
i have a question about your valve covers first off the look great,second on the aftermarket valve covers ive seen theres no where to pour the oil and is that rubber hose coming from the intake on the passengers side neccessary and also how did u chrome or polish yours thx
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Dec 6, 2015 11:25 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
