Will this roller cam idle smooth? (Specs)
Car: 2000 BMW M5
Hi guys, I just bought a custom ground roller cam to use in a Stealth Rammed 355. Here are the specs w/ 1.5 rockers
0.495"/0.530" i/e 222/230 i/e @.050 on a 114 lsa
I have a wideband (finally) and burn my own chips, but I still hope this cam idles fairly smooth. I'm sick of choppy idling cams that smell like gas at idle no matter what I do to fueling. I figure the 114 LSA and pretty conservative duration (for an aftermarket high HP build) should have this thing idling pretty reasonably smooth. What do you think?
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I had a 236/242 @050 XE that idled pretty smooth, the rollers are pretty calm, my 230/236 @050 flat tappet idles harder, makes the car shake...
Car: 87 Camaro IROC
its your LSA that determines rough idle or not, a high LSA will make an engine run smooth, and a low LSA will produce more low-end power, but your idle will suffer.
Car: 91 formula ws6
Engine: 1 peice roller scat 383 4 BOLT!!
Transmission: 5 speed
zz4 has very similar specs, and is 150 brand new on ebay all the time
just a suggestion . love the car
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
that that cam is pretty tame, it should make good power yet idle nicely. and it doesnt have all that much lift either
Car: 1987 Pontiac GTA
Transmission: Haven't decided yet ;)
Idle quality ????
The overlap @ .050 is what will determine how your engine is going to idle. With a 355c.i. engine, i would say 10 degrees is pushing it. You can have 3 cams that have the same adv. duration and lift numbers, and they all three can act completely different. Open & closing events combined with L/S angle is what affects the idle. A good rule of thumb is (c.i)divided by(overlap @.050) example-406/13=31.2% ... this ratio is a good guide to help determine how a cam is going to idle. If you start to go below 30%, you will see how the idle starts to chop. EFI can tolerate more overlap@.050 than carb. engines, so keep that in mind as well, with proper tuning of course. I'd say much less than 25% with EFI and you will have your hands full with the idle issue.
Car: Death Mobile
Engine: 666 c.i.
The LSA's primary function determines the power band rpm range of the cam. A narrow LSA cam (110) tends to promote mid-range torque while a wide LSA will sacrifice mid-range TQ for a higher top end.
Large cams often will go with a narrower LSA because the large duration itself often promotes major HP so they often look to compensate by increase mid-range TQ while sacrificing a little at the top end. A short duration cam tends to be weak on HP so a wider LSA will help increase top-end HP while sacrificing little TQ.
But it is the overlap between the exhaust closing and intake opening that determines the idle quality more than anything else.
PS: I just noticed twinturbo406 said basically the same thing. So you add my vote as agreeing with twinturbo406's comments.
Car: 2000 BMW M5
Pennock, thanks (and thanks everyone else too!). This cam cost me $100 new, I got it in the mail the other day. Sounds like I'll be in good shape.
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
make sure you get a new prom burned or the cam will throw your computer and air/fuel ratio wayyyyyy outta wack
Car: 2000 BMW M5
I don't get "proms burned", I burn them myself. I datalog and have a wideband O2. Only way to fly. I couldn't imagine running EFI with any engine mods without doing your own chip work (or having someone with a dyno and a wideband do it)
Car: Death Mobile
Engine: 666 c.i.
junkcltr
Aug 2, 2019 11:12 PM
ambainb
Apr 25, 2016 09:21 PM
