wanna get some head...s
Old Feb 8, 2007 | 10:57 PM
Jap408Cracker's Avatar
Car: 87 IrocZ/87 Iroc Z28
Engine: L98 350 TPI/ LT1 350
Transmission: BW T5 5spd/ 700r4 A4
Axle/Gears: 10 bolt posi 4.10/10 bolt posi 3.73
what up guys.. i just got my financial aid check and want to put about 2k into my camaro. i was looking at getting some new heads but not sure. i want to get some nice flowing ones that can give some good power, but i wasnt sure on what to get. i got a 350 tune port thats all stock. should i get a new cam and intake manifold to go with it?? will my headers bolt up to the new heads? is there any good package deals that come as a set?
thanks..... nick
Old Feb 8, 2007 | 11:20 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Your title is a little inappropriate.
There are dozens of great heads. If you want to spend 2k then go with some AFR Eliminators. Handles up to .600 lift so you can run a crazy cam if you want. Yes your headers will bolt up.
Or you can purchase some lesser expensive heads and get a Stealth Ram intake and ditch the TPI. Since TPI is so restrictive, the AFR's performance will be minimal.
Old Feb 8, 2007 | 11:29 PM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
http://store.summitracing.com/partde...5&autoview=sku
these are decent heads. i have them on my 383 and i'm very happy with them. i would also do the lt4 hot cam from GMPP and better flowing intake base, runners, and 1.6 full roller rockers. if you have enough left over i would also stick a new throtle body on there that flows better.
Old Feb 8, 2007 | 11:54 PM
i thought the stealth ram doesnt have an EGR and wont be smog legal. i live in california so its pretty strict, but whatever. i wanna get around 360 hp, will those heads, intake man, rockers, cam, and runners get me there? should i go with a 52/54 mm tb? know any good packages and where???? wanted to get peoples attention so i threw out that title.... sorry
Old Feb 9, 2007 | 02:08 AM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
financial aid bro .....drop it back into school, and youll be able to drop a 572 in your camaro in a no time!
Old Feb 9, 2007 | 08:34 AM
Boosted_SS's Avatar
Engine: 383 TPI
i have a 383 with a similar combo and i'm over 450 so i think it should be able to yield you over 360.
Old Feb 9, 2007 | 07:25 PM
i am willing to spend the money now and get some nice heads. can you guys point me in the direction of where to go? trickflow, edelbrock, summit? was told edelbrock wont give the best bang for my buck.....
Old Feb 9, 2007 | 07:32 PM
Boosted_SS's Avatar
Engine: 383 TPI
i have the same heads as i showed you above except i have the 74CC combustion chambers and i really like em.
Old Feb 9, 2007 | 07:36 PM
how much better would aluminum be?
Old Feb 9, 2007 | 09:18 PM
Boosted_SS's Avatar
Engine: 383 TPI
only advantage to aluminum in my eyes is weight reduction and heat dissipation.
the down falls of aluminum are that if you don't have the proper head gasket you can have head gasket issues (because aluminum and cast iron (the block) expand at different rates), if you overheat the car even slightly you have a very good chance of warping the heads, and the bolt holes are easily stripped by over tightening or cross threading.
Abubaca
Car Audio
Sep 24, 2015 02:33 AM
Tylermcclinton
Sep 17, 2015 07:50 PM
Veaceonee
South West Region
Sep 6, 2015 10:04 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
Cacike
Aug 27, 2015 05:10 PM
