Would an LT1 engine run with TPI electronics?
Old Feb 28, 2007 | 06:49 PM
CochinoFilipino's Avatar
Car: '67 C10
Engine: 5.0 TPI
Axle/Gears: Yes
Say I came across an LT1 engine without wirring or ECM, could the gen 2 engine with it's LT1 intake run with the TPI sensors and ECM?
Old Feb 28, 2007 | 06:53 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Why not??? You maybe need to re-wire the inputs for the optispark to the wiring for the old distributor module and coil????
I would love to hear that someone has done this...
Old Feb 28, 2007 | 06:59 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Why not just get an LT1 engine harness...seems easy enough to find? Sounds like too much work to try and re-use the TPI harness.
Old Feb 28, 2007 | 08:06 PM
APACHE JOHN's Avatar
Car: 1991 Z28
Engine: 350 TPI RAMJET COMING
lots of ways to go go about this I've carbed them also. Gotta remember they're not real superior to a L98.
Old Feb 28, 2007 | 08:23 PM
Stevo's Avatar
ya, the intake thats it...rest of the motor is almost the same as a 350 TPI.
Old Mar 1, 2007 | 12:07 PM
Car: '67 C10
Engine: 5.0 TPI
Axle/Gears: Yes
If I go through the trouble to upgrade from the 5.0 to the 5.7 I'd probably end up getting an aftermarket intake down the line anyway. Seems like most of you guys with mods don't run a stock TPI intake. I was thinking it may be cheaper just to swap in a whole LT1.
I was wondering if the swap could be easily done.
Old Mar 3, 2007 | 05:41 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Huh.......optispark on the front of the motor, reverse rotation cooling, different exhaust port height, all water hosing different........not to much is the same between the two at all....
Old Mar 3, 2007 | 09:24 PM
Vader's Avatar
Not to mention the PM connecting rods, lighter and better balanced rotating assembly, lighter valve train, better heads, and probably others that have been forgotten.
Old Mar 6, 2007 | 07:10 PM
JB97C5's Avatar
Car: Silver 1980 Corvette (L82 w/TPI)
Engine: L82
Transmission: TH350
It is really easier than you think-
  • Pull the intake and drill the back for a distributor.
  • Remove the Opti-Spark (or go ghetto and leave it!)
  • You'll need to use a MAP or a MAF sensor- but you won't need both (just remember to use the right one with the right system- Mass Air versus Speed Density).
  • It will need a custom chip.
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
86IROC112
Aug 17, 2015 02:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
