dual MAF for TPI 3RD GEN ? is it possible? has anyone tried this?
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
the idea is to make the throttle body witha a adapter into two seperate pieces. one butterfly for each MAF. I will be spiicing into the current harness and in simple terms put a MAF on each new throttle body that has been split into two.a MAF for each throttle body butterfly plate . I will then run the duct a y shaped aftermarket unit(available from corvette) to the new throttle body that has a new divider for each side. Now there will be a MAF on the other ends on the y pipe. I will then run duct work down through to the fog lights for a ram air. Is this possible to make these TPI torque monsters finally have top end power were they always seem to drop off at the H.P. numbers. Has this been attempted? am I on to something here?
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
How do you expect this to work? What is the ECM going to be reading?
Personally, I think that its better to build a single but larger OD MAF sensor.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Get an LS1 MAF, converter, and tweak the injector constant/tables so the ECM can see past 255 gms/sec. The 255 gms/sec part is what usually holds the motor back. You can also fudge the fueling, but it would be better if the ECM could actually see the true airflow.
Car: 1983 G20 Chevy
Transmission: 4L60
Mod a later model TBI PCM to run in PFI mode and run Dimented24x7's MAF code in it, using a LS1 MAF. Re-pin the harness from the 165 to the 427.
Cold engine WOT acceleration, a slight bog, but the AE fueling still needs work (wet manifolds suck when they are cold).
http://youtube.com/watch?v=p2kH39oC8O0
This is just messing around with a warmed up engine.
http://youtube.com/watch?v=sNgHi85M6AY
It IS LS1 MAF run
http://youtube.com/watch?v=7nVQePIYzhI
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
