Just gotmy self a 89 350 TPI w/ disk brake rear & Posi :)
Old Mar 4, 2007 | 08:45 PM
BigBoi4Lyph's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
So i ended up tracing the 86 for a 84 s10 lowered primered gay about 2 months ago or more( 2nd gear finally blew out too on the car so i let it go.) Now i just traded the s10 blazer for an 89 iroc hard top 350 TPI With the Borg (sp?) 9 bolt posi disk rear end very nice car but it has alot of little **** to do and a paint job the damn Vats is acting up so im going to bypass that asap heres some pics the car actually has alot more clear peeling then the pics looks like it has but the TPI drives as fast as it looks
Ohh and flowmasters
Its the Red one is mine the green one is the sellers 91 305 tbi 5 speed
Old Mar 4, 2007 | 09:00 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
good find, looks sharp.
Old Mar 4, 2007 | 09:02 PM
Car: 89 Iroc
Engine: 5.7 TPI
Yea its ok like i said really bad clear coat peeling and the 2 frong fenders have take a little tole but as far as the running gear its pretty good
Old Mar 4, 2007 | 09:31 PM
Car: 89 Iroc
Engine: 5.7 TPI
Just got back from a test drive, ahah i need to calm down or ima end up with tickets. Ima have to say tho wooo for TPI
Old Mar 5, 2007 | 05:14 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
Welcome to the party!
Old Mar 5, 2007 | 08:28 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Congrats. Now the fun begins.
BTW - what color is primer gay?
Old Mar 5, 2007 | 09:11 AM
Car: 89 Iroc
Engine: 5.7 TPI
Opps ment to say Gray but the gay worked too lol id rather have this TPi with chipping clear coat then a lil blazer with 5 different shades of primer all over
Old Mar 8, 2007 | 05:57 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Could someone explain to me what the Vats is and what it does when it acts up? Sorry for the hijack. Nice car btw.
Old Mar 8, 2007 | 07:57 PM
Car: 89 Iroc
Engine: 5.7 TPI
No problem man are you having a problem with vats or do you just want to know what it is? Im not shure if you have it in your i had an 86 and mine didnt have vats in it. But its basicly a silent alarm when you put your key in the ignition if it has the black chip looking thing in it it goes between 2 metal prongs, brushes ( some sort of metal touching both sides of the chip. this information is sent to the ecu or vats box ? im not positive but either onme read the information and if the resistance in the key matches that in the ecm or vats box your car will start if not( of if you have the common problem of the wire breaking on the lock cylander orany other vats problem the ecm sees the wrong resistance and locks out your starter (it might lock out more but i know when mine was tripping the car just wont crank period).
Old Mar 9, 2007 | 10:37 AM
subroc's Avatar
Engine: 355 TPI
Oh ok thanks for the info. My car is giving me some problems and i was just wondering if that could be it. But im pretty sure my car does not have that feature.
Old Mar 9, 2007 | 10:39 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Pretty sure? The black chip in your ignition key is the dead giveaway.
Old Mar 12, 2007 | 12:08 PM
subroc's Avatar
Engine: 355 TPI
oh didnt read carefully enough. Yea i dont have the Vats.
Old Mar 12, 2007 | 08:06 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
nice trade
Old Mar 13, 2007 | 09:19 AM
Car: 89 Iroc
Engine: 5.7 TPI
Thanks!
cheesehomer
Dec 31, 2015 08:48 AM
KO1
16
Oct 15, 2015 05:00 PM
loud91rs
Oct 5, 2015 10:05 PM
thejimsterz28
Sep 30, 2015 08:52 PM
92projectcamaro
Sep 29, 2015 07:07 PM
