how can you tell if you have vortec heads?
Car: 1991 Gta trans am
Engine: 383ci,trickflow alum. heads, hsr
Transmission: T-56, alumin. driveshaft
Axle/Gears: stock 7.5"/3.42
Can you guys lighten this subject for me because I thought I had vortecs on my car but I don't know how to tell the difference? The motor is a 1991 350 l98, I thought almost all tpi cars came with them.
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
As far as I am aware no third gen came with vortec's. If they did, the manifold from those cars would be sought after big time. Then we wouldn't have to buy the scoggin dickey mainfold.
Hope I didn't burst your bubble.
no you didn't but hey how much hp increase would I see If I bought a pair? .......And where could I find them? lol
Keep in mind that you need a new intake manifold to make the vortec heads fit our cars. There is an edelbrock one available a summit and the same one at SDPC.com About 400$. I've heard about 30+hp depending on the vortec's you get, porting, valves etc. Cam and heads go hand in hand. I won't be building my motor till next year. Maybe.
oh ok well i was going to put a summit cam in my car anyway do you think i can get both for like $1500 or less?
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Seeing as how "Vortec" heads didn't come out until 1996, no third gens would have come with them... I see so many people think that their '87-'95 heads are vortec heads because the center intake manifold bolts are at a different angle... SOOOO many people think they have some special "Vortec" head, which is just a buzz-word anyway for fast-burn chambers and raised intake ports.. An easy way to identify Vortec heads is to count the number of intake manifold bolts that hold the manifold down... Vortec heads will have two bolts in each corner of the engine, all of them are perpendicular to the ground with the engine sitting in the car.. So if you have 8 bolts, and they're straight up and down, then it's probably vortec heads...
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 1995 Corvette
Well, I'd consider a Gen-II LT1 quite different from a traditional SBC, but not really a vortec engine.. Granted, the heads are good heads, but other than the induction system (which doesn't come into my equation, you can put many forms of induction on any engine), there's not a lot of primary differences other than the cylinder heads in a Vortec engine..
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Then there is also differences in the rockers, self aligning vs not, and associated pushrods for each. If you go with the older heads on a roller motor make sure you get the vette pushrods because they are hardened for use with guide plates. The old style harded pushrods wont be the right length.
-- Joe
Car: 86 iroc z
Engine: 305 tpi
Axle/Gears: 3.42:1
if you remove your intake manifold the intake ports are larger that most others and the stamp number along the side below the valve cover on the manifold side, can be ran to see fore sure look you numbers up to make sure completely. As i knew it 4th gen were the cameos that had the vortecs maybe a few latter third gen ones had them i don't know, but you can get a set on eBay or a machine shop can mill some to fit your block, but i have the left side vortec head that will fit most or all 350's, it brand new, my step dad works and Delphi and made a calibration machine for Gm vortec heads and he got the head from work, if you pay for shipping and give me $75.00 obo, i would sell you it. a good source to find the other side is eBay, you can find good deals on just one or get a set, i am going to make a lamp out of it if not lol.
wow thanks, finally a forum that will answer my questions. Ok so let me get this straight.....I need to slot as in make the bolt holes longer? how does that affect the ports? If I was going to buy a new HSR manifold what would I buy to fit these headshttp://www.midwestmotorsportsinc.com/order_part.php?item=PPHEAD&line=MWM
Car: 1995 Corvette
Those look like just standard SBC heads, so you'd get the regular 7540 (I think thats the PN for the standard) HSR.
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
