90 TPI sensor help
Old Mar 13, 2007 | 07:40 PM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
90 TPI sensor help
I just bought a used motor to rebuild, and while taking it apart i found a sensor on the right head, that was melted away, and I have no idea what it is or what it's for....If it helps it has blue plastic on the inside????????????
does anyone have a diagram that shows where and what ALL the sensors are so I can get them replaced..
any help would be nice......
Old Mar 13, 2007 | 09:40 PM
383 iroc's Avatar
if it was in the head most likely it is your coolant temp sensor that goes to the gauge
Old Mar 13, 2007 | 10:14 PM
ajk511's Avatar
Car: 1991 z28
if thats the CTS then whats the one on the pass. side of the block by the knock sensor? the harness connector to it broke will i was doing a tune up and my temp. gage stopped working. i got the same motor, 91 l98
Old Mar 13, 2007 | 11:07 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Wrong....that is the fan temp switch in the right side head.
The CTS is in the front of the manifold....two wires blk-yel.
The guage temp switch is in the left head.
Old Mar 14, 2007 | 07:07 AM
gscz28's Avatar
Car: 89 iroc
I think it is for the the second fan, this is a dual fan setup,....question does anyone have a part number for the second fan sensor?
or are they the same for both sides?
Old Mar 14, 2007 | 07:31 PM
cranknrods's Avatar
Car: 92 RS
Engine: 350vortec
the temp sensor for the gauge and the fan should be the same part number-hold on and ill log onto "alldata" and check it out for you
Old Mar 14, 2007 | 07:40 PM
cranknrods's Avatar
Car: 92 RS
Engine: 350vortec
p# sw502 from autozone $5.99
i was wrong-its not the same sensor
hope this helps
Old Mar 15, 2007 | 10:39 AM
gscz28's Avatar
Car: 89 iroc
thanks for the help
Old Mar 15, 2007 | 04:36 PM
gscz28's Avatar
Car: 89 iroc
okay that was not the right sensor, here is what the sensor looks like and it is between the 6-8 spark plug cylinders.
the end of the sensor is melted off
some help would be appreciated
Attached Thumbnails 90 TPI sensor help-dscf0165.jpg   90 TPI sensor help-dscf0166.jpg
Old Mar 15, 2007 | 06:21 PM
gscz28's Avatar
Car: 89 iroc
here are a couple better pic's you can easily can see the difference,
and some more clues maybe.
I just looked at the harness, and it seems that there is a plug by the wires for the started, it's white and with 1 female connector, and has a blue wire.
Any idea what that plug would go to?
some help please
Attached Thumbnails 90 TPI sensor help-dscf0169.jpg   90 TPI sensor help-dscf0170.jpg
Old Mar 15, 2007 | 07:23 PM
gscz28's Avatar
Car: 89 iroc
alright I just matched it to the harness and it's all good
thanks guys
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
