23# injectors, made by Rochester
Old Mar 17, 2007 | 12:11 PM
88I_R_O_C_ZTPI's Avatar
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
will 23# injectors made by Rochester out of a 91 L98 corvette work in my 88 l98 iroc ? my car is stock . would these be a direct replacement ? the #'s on them are 8300 7086544
Old Mar 17, 2007 | 08:38 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Yes they will work, Just buy a new Oring kit b4 you put them in.
Old Mar 17, 2007 | 09:54 PM
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
will do . just curios , i know the stock injectors are 22# but how many #"s can you go up before needing to reprogram the prom ?
Old Mar 18, 2007 | 01:06 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Corvette L98 350's have the same 22lb injectors as Camaro/Firebird L98 350's.
People have swapped from 22lbs to 24lbs and needed a chip reprogram, so its a big thing.
Old Mar 19, 2007 | 03:33 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
544's are known to go bad, I wouldn't use them unless they are fairly new.
Those are the ones they call multecs.
Old Mar 19, 2007 | 05:01 PM
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
which would you recommend that will not break the bank and are direct replacements ?
Old Mar 20, 2007 | 12:27 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Re: 23# injectors, made by Rochester
I put in LT1 injectors in my car. 24# Yes I did have to have it tunned. But My stock ones were only 19#. Dont forget a adjustable fuel pressure regulator.
I know they make SVO 19# ones. I'd look on Ebay.
Old Mar 24, 2007 | 07:27 AM
C6matt's Avatar
Car: 05 C6, 91 z28 Vert, 66 Mustang vert
Engine: Ls2, TPI 350, 289 4bbl
Transmission: T-56, T-5, C4
Axle/Gears: 3.42,3.08,3.73
I just got accel 23# to replace the accel 30# that were in there. I know the stigma about accell injectors, and on the 23# box it says new design.. and they really look better ( higher quality) than the old design 30#'ers
snd he was running the stock prom with the 30# injectors... ran like CRAP...
now its 350 wit h bbk 58mm TB,headers, an 23# injectors with a custom PROM.. its not all back together.. but soon... hope the T5 holds up...
Infested
May 22, 2018 11:56 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Thornburg
Aug 27, 2015 08:33 PM
lakeffect2
Aug 23, 2015 08:44 AM
kyleb24
Aug 15, 2015 08:24 AM
