throttle body be bad?
Old Mar 18, 2007 | 11:07 AM
bigtom88transam's Avatar
Car: 88 trans am, and 06 focus DOHC
Engine: 305 tpi
Axle/Gears: 4.56 screaming pave eating :-)
hey i was talking to my father in law and he said that possibly my throttle body could be bad due to the excessive fuel consumption and overloading with gas??? anyone have opinion or fact upon this???
im thinking overload of gas would have to be due to lack of air getting into the motor?
Old Mar 18, 2007 | 12:28 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Sounds more like you have some bad injectors, and they're leaking gas into the cylinders. Get an ohm meter and measure the resistance of each injector. It should be between 14-16 ohms. If you find any that are under 10, they're bad.
Another possibility is a bad rubber in the fuel pressure regulator. That will allow gas to leak past it.
Old Mar 18, 2007 | 12:46 PM
Engine: 305 tpi
will have to do that i just replaced the FPR last month so im pretty sure its not gonna be that now
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
