pics of stock GM TB vs. 58mm throttle body
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
I ordered a new 58mm TB from summit. Took some pics:
Car: '88 Camaro
Engine: 5.7 L98
Re: pics of stock GM TB vs. 58mm throttle body
Did you learn this from experience? If so, tell me you have a pic.
for the heads up.
for the heads up. Guest
Posts: n/a
I didnt bore the holes, but I told them to just drill away and I'll fix it later. Had the plenum welded up on that side and smoothed it out on the inside. I also had to alter the runner to clear the weld.
I have pictures somewhere.
https://www.thirdgen.org/forums/tpi/...hat-i-had.html
Car: '88 Camaro
Engine: 5.7 L98
Thanks for the info. I plan on building a 383 stroker in the future, but for now, all my $ is going to my '54 Chevy truck project with a very mild 350. Will I need to do any tuning to the ECM in order to run the 58mm TB and AZ. S&M runners with the stock base and port matched plenum? When I get to the 383 I'll get a better flowing base intake, but for now the IROC is a daily driver. I do realize that the 58mm is overkill for the stock L98 with stock heads, but I only wanted to buy the parts I needed once. My polished intake/runners/TB on my IROC will be going on the '54. I got the AZ. runners and 58mm TB for the satin look. See the '54 project link in my sig.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I had both sides welded up when I modified my plenum to 58mm like you did. When they are blended in it looks factory.
Car: '88 Camaro
Engine: 5.7 L98
I just got off the phone with Ben at AZ. S&M and they have no record of my order last week
So now I'm 3 weeks out on my runners
I'll update this when the port matching is done.
I'll update this when the port matching is done. Trending Topics
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
There are people on an AS&M runner group purchase on this board that have been waiting since September. You've got a long wait. Thread Starter
Car: '88 Camaro
Engine: 5.7 L98
I paid $435. How much would I have saved with the GP?
Car: '88 Camaro
Engine: 5.7 L98
Are they made by AZ. S&M or does someone else produce them? Are TPIS' comparable?
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
TPiS and AS&M runners are identical. TPiS bought the plans from AS&M and then mark'em up.
They are separate companies that make the same thing just under different brand names.
Terrell351
Jun 13, 2021 01:13 PM
