Ram Air system = Cold Air Intake????
Old Mar 21, 2007 | 02:25 AM
The_Phoenix's Avatar
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
I just wanted to know if the Ram Air type system is the same as a cold air intake system but in another version since it pulls air in from the outside?
Old Mar 21, 2007 | 05:57 AM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Re: Ram Air system = Cold Air Intake????
Actually you could consider it a Ambient Air temperature Intake, Cold day u get cold, Warm u get warm
They call it ram air because of the air molecules getting "rammed" Into the front of it at most speeds, Some people have had good results with a kit for it but all in all a cold air intake should yield more horsepower.
Old Mar 24, 2007 | 02:11 PM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Cool! thanx for the info man! One More Question....How Does a Cold Air Intake System pull cool air in on a hot day?
Old Mar 24, 2007 | 02:41 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
It doesn't. "Cold" is relative. Cold air intakes draw air from places outside of the engine bay- so it won't draw in heat from the engine. Basically it's colder-are-than-in-the-engine-bay intake.
Old Mar 24, 2007 | 08:36 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
Exactly, its Relative
And thats the reason they make more horsepower, Cold air is more dense
Old Mar 25, 2007 | 10:06 AM
jmiller's Avatar
Car: 87 IROC - 67 Camaro
Engine: 383 TPI - ZZ4 TPI
Transmission: 700R4 in both cars
Axle/Gears: 3.27 - 3.36 posi in both cars
I just thought to mention this. I have a 2" cowl induction hood that allows outside air to enter over the plenum and have noticed thru monitoring that the air tempature in the plenum is at least 30 degrees cooler than before I put the hood on. I still have a cold air induction in the front but the added feature of a colder plenum helps even more!!!
Old Mar 25, 2007 | 02:31 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
The ram air intake up front IS a cold air intake. If you have a cone filter in the fender well, or the air inlets at the front grille both of these are going to pull in air of the same temprature. Also nice tip on the cowl hood.
Old Mar 25, 2007 | 03:20 PM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
All things being equal a ram air system will make more power than a regular cold air intake without the ram air, not a lot but it all helps.
9192camaro
16
Feb 3, 2019 12:21 AM
kyle5647
Aug 15, 2015 11:56 PM
bryan623
Aug 10, 2015 11:33 AM
