Need help with Tpi engine vacuum layout
Old Apr 10, 2007 | 10:07 PM
JohnnyBravo's Avatar
Car: 1987 Trans Am
Engine: 305 5.0 L v8
Transmission: 5spd manual
Can anyone please give me some advice on where i should go for detailed images with labels pointing out where vacuum connectors, coolant lines, electrical connectors etc. where they go/belong and what they ultimately connect to... ive got an 87 tpi 5.0 engine on a T/A and am unable to find this information.. ive reconnected everything with the help of a labeling system but 1 or 2 connectors remain and im not sure exactly where to reattach them... perhaps if u could give me a link to photos of where everything goes.
Ive gone through all the manuals i could but none of them seem to have detailed information, they assume that u already know how everything is / how it goes.
It would really help me get my bird back together asap.
Old Apr 11, 2007 | 05:42 PM
Planetcamaro's Avatar
Car: 1989 Camaro Z28
Engine: Transplanted 5.7 TPI
Axle/Gears: ?
Re: Need help with Tpi engine vacuum layout
Hope this helps, here you go, vacum and wiring harness diagram.....I not have time to look up the hose routing, I will look later tonight, some in pdf some in gif format...
Attached Thumbnails Need help with Tpi engine vacuum layout-fig.-24-1987-1989
Last edited by Planetcamaro; Apr 11, 2007 at 05:59 PM. Reason: edit body, inserting image
Old Apr 11, 2007 | 06:00 PM
Axle/Gears: ?
Let me know if you want the body wiring harness diagram.
Old Apr 11, 2007 | 06:04 PM
Car: 1987 Trans Am
Well ive got a couple black hoses running from that thing in the right front corner of the hood ( im assuming it is part of the cruise control system as it seems to directly respond to changes in throttle position) and it splits into 2 lines in the middle of it, on the other side i have a similar hose that also seems to have no corresponding plugs but ill look at what youve sent me and try to go from there
my email is
noqeustions@hotmail.com
are those hoses shown in teh diagram the only essential ones.. if i miss some of the others will the car still run / idle properly?
Last edited by JohnnyBravo; Apr 11, 2007 at 06:09 PM. Reason: Automerged Doublepost
Old Apr 11, 2007 | 06:10 PM
Axle/Gears: ?
Here is the body wiring hareness.
Emailed you some more stuff... Gotta go home be back later....
File Type: pdf
Old Apr 11, 2007 | 06:20 PM
Car: 1987 Trans Am
Alright ill take a look at it.. ill try and take another look at the car right now, and see if i can get this stuff figuired out
THANKS SO MUCH!
i think ive got the elctrical back together fine its just those hoses that are tough to figuire out but what is that thing in the right front of the car that acts like a diaphram when the throttle / cruise control cable is actuated? its the one thats got a hose coming out of it that later splits into 2
Old Apr 11, 2007 | 06:23 PM
Axle/Gears: ?
Not sure? Im just a computer guy with a Camaro and loads of info(manuals) at my finger tips...
Old Apr 11, 2007 | 06:45 PM
Car: 1987 Trans Am
ok ive been lookin at the drawings and comparing it to what ive got connected.. ive got one more request.. if u know where the 3 connectors from that absolute vacuum unit at the back of the engine belong please let me know or some diagrams in regards to the absolute vacuum thing and finally the hose routing from the vapour canister go.. if i can get the diagrams for those ill stop asking silly questions !!
Old Apr 13, 2007 | 01:31 PM
Axle/Gears: ?
I havent been able to find anything on the Vacum Unit, On the Vapor Canister I belive the first diagram I posted should have those? The one called Fig 24.
Old Apr 13, 2007 | 01:35 PM
Axle/Gears: ?
Here Is one more on the Canister...
Old Aug 15, 2012 | 04:12 PM
<CHeVy_GiRL>'s Avatar
Car: 86' camaro
Engine: 5.0 tpi
I just wanted to say that ive been needing all of these diagrams for a very long time.. now i can finally finish my motor work and get down to the body work and interior.. thank you very much!!!!!!!
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Sep 3, 2015 10:56 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
