Bigmouth passages
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Bigmouth passages
There are 3 ports on the front of the TPiS Bigmouth base. 1 gets a coolant nipple, 1 gets a coolant sensor, and the other gets plugged. Those of you that have the bigmouth base, what did you use to plug it? Size? Pitch?
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Re: Bigmouth passages
Its a pipe thread....can't remember..either 3/8" or 1/2" pipe plug
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
correct it is 9/16", but npt sizes are way different, you need a 3/8" NPT plug for that hole. most parts stores carry these, even hardware store for under a buck.
Car: 92 GTA/ 00 TA
Engine: 383/350
I got a 3/8 npt plug today. Talk about tight. I can barely get the thing started. I wonder if my casting is bad. I had to grind a big of metal away from around the vacuum port just to get that nipple in.
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
It should go in just dont try to force it in all at once. Back it off a few times with some teflon and it should go in. It wouldnt hurt to run a tap through first.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I put my fan switch in that third hole, and extended the wires to it. That keeps it away from the headers and keeps the connector from getting brittle and breaking.
Then just plug the hole in the head.
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
