anybody used the summit tpi cam kit?
Old Apr 17, 2007 | 07:21 AM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
http://store.summitracing.com/partde...0&autoview=sku
anybody ever used this? wondering how well it performs not for my car but for my new project car. it is non roller 1986 so if i can get me a cam kit for $125 and really pick up 40 hp it will be worth it to me. im going to have to change the harmonic balancer so i figured id just pop the timing chain off while im down there and pull the intake and swap the cam. let me know what you guys think about it if you think it will help that much imma slap it in there.
Old Apr 18, 2007 | 11:35 AM
Car: 88 IROC
Re: anybody used the summit tpi cam kit?
no one has used this cam i searched but i didnt see many results from it. id like to know so i can throw it in.
Old Apr 18, 2007 | 12:12 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I used it for about 10 miles
I was having problems with wiping cam lobes so I bought that kit because it was cheap.
for the little time I drove it, it seemed to have decent power and the throttle response was pretty good.
If I had a non roller block and it was a project car on a budget I would definatly recomend that cam kit
use the springs!
Old Apr 18, 2007 | 06:43 PM
rel3rd's Avatar
Car: 1967 Camaro
Engine: 327
Transmission: Turbo 350
Axle/Gears: 308's
I have that exact camshaft waiting to go in my non-roller L98. I didn't buy the complete "TPI" kit with the springs because I have new heads already equipped with (obviously) new springs. I also have 1.6 roller rockers to raise the gross lift a little. (.448"/.471" VS. .420"/.442")
I hope to have it in within the next 2 weeks and will make a post with my impressions of it. Considering my car made 239rwhp/359rwtq with a semi-clogged cat and a wiped cam lobe on the stock cam, I'm pretty sure this mild cam will suit me just fine.
Old Apr 19, 2007 | 10:25 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
more feedback please.. im also considering this cam. also im adding a procharger soon. should i even do a cam??? any input would help guys.
Old Apr 19, 2007 | 11:27 AM
Car: 88 IROC
rel3rd let me know how it works for you im seriously thinking about getting it. i am going to change the timing chain out for a double roller and throw this cam kit in there. ill probably port the intake a little myself.
Old Apr 19, 2007 | 02:22 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
that sux, was just looking more at the cam set, its only for 85 86 cars, i guess no good on my 89 roller motor???
Old Apr 19, 2007 | 03:15 PM
rel3rd's Avatar
Car: 1967 Camaro
Engine: 327
Axle/Gears: 308's
I absolutely will post, if not here, in a new thread. I hope to have it in and back together by next weekend.
IMO, you have a lot more (better) options with a roller
Old May 6, 2007 | 06:54 PM
rel3rd's Avatar
Car: 1967 Camaro
Engine: 327
Axle/Gears: 308's
Finally got it back together. So far, I think it's a great option to a stocker. No idles issues. No driveability issues and very responsive throttle. It will lug aroung in OD at 1200 rpm's, yet rev cleanly to 5500.
Here's a video I made today after a fresh oil change.
http://www.youtube.com/watch?v=6NKIElc4mbg
Old May 6, 2007 | 07:16 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I put the complete kit in my wife's TPI back in the winter.
Her car will be ready to fire next week if everything goes okay. It looked like a good deal. I had the heads prof ported while building engine.
I hope the combo works good witn 1.6 rr.
I'll let you guys know if it runs.
Ron
Old May 6, 2007 | 07:17 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
I can't use on either of my '89 motors, but it has nice lope. GOOD LUCK
Old May 6, 2007 | 07:46 PM
rel3rd's Avatar
Car: 1967 Camaro
Engine: 327
Axle/Gears: 308's
Ron
Ron, I'm running 1.6's myself.
Thanks a lot!
I'm just glad to finally get my car back in shape for the Summer.
Old May 7, 2007 | 07:21 AM
Car: 88 IROC
how is the performance? do you think its worth the trouble to put it in?
Old May 7, 2007 | 08:47 AM
rel3rd's Avatar
Car: 1967 Camaro
Engine: 327
Axle/Gears: 308's
It works very well IMO...
I put up a review type thread last night:
https://www.thirdgen.org/forums/tpi/...ams-first.html
Old May 7, 2007 | 11:38 AM
Car: 88 IROC
cool i look forward to seeing that dyno sheet. im going to be stuffing this cam in a basically stock 305 tpi so the main thing im worried about is it working well with the computer.
Old May 7, 2007 | 02:52 PM
rel3rd's Avatar
Car: 1967 Camaro
Engine: 327
Axle/Gears: 308's
Today is the 3rd day driving it so far and it has been great.
I let her rip once OR TWICE today and it feels like a new car.
Old May 8, 2007 | 01:42 AM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I am very picky when it comes to driveability. I hated my hotcam and I semi-dislike my LPE219. The Summit 204/214 was completely tame, great powerband as Bob said, although my combo ran outta steam before 5000rpm but most likely due to the swirlport heads and stock TPI. Overall, driveability was awesome after it was tuned.
Old May 8, 2007 | 03:43 AM
F-Body Demon's Avatar
Maroon88iroc....Do it...you will love the power. I know a guy who used that cam in a 305 with a airfoil and a Cold Air Intake, and he ran a 14.9 at 8000 altitude . Thats about High 13s or low 14s down at sea level. You will enjoy it alot. But you can save time by pulling the radiator and stuff off the front of the car and just leave the engine bolted in. If you wernt going to do it that way, I would.
Good luck buddy!
Old May 8, 2007 | 06:58 AM
1988CamaroSC's Avatar
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
thats one snotty vette. sounds real nice.
Old May 8, 2007 | 07:39 AM
Car: 88 IROC
Good luck buddy!
well looks like your post has me sold. 14.9 at that level is a very good time. ill throw this cam in and see how it does. thanks for the info everyone!
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro71633
Sep 1, 2015 10:24 AM
TreDeClaw
Aug 14, 2015 06:58 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
