More power!
Old May 3, 2007 | 07:59 PM
cpears's Avatar
Car: 1988 IROC
Transmission: TH-700r4
More power!
Hey guys, I recently purchased an 88 Iroc with a brand new 305 in it. It has a some pretty decent power but I want more. I put a set of shorty headers on it, underdrive pulleys, a/c and smog delete pulleys, and K&N filters. I want to put a cam in it but here is the kicker. Car is NOT a daily driver, so I want to go poweful but attain great driving characteristics. I have heard that I can put a LT1 cam in it for a 94 or new camaro/firebird? is this true? recemended? What will I need different rockers/valve springs? I have thought about doing the LT1 intake swap, will it help on a 305? I have a 2,300 stall and stock rear end at the moment.
Old May 3, 2007 | 09:00 PM
patgta's Avatar
Re: More power!
First you have to set your goals. How much power are you looking for? 300, 400 or 500 at the wheels. 300 and your fine with the tpi setup. 400 hp and you will need LT1 intake and some seriously mods (if your still using that 305 motor). 500 hp+ maybe you should consider swap for a bigger engine such as a 383.
Basically in the end it really comes down to setting your goals and then looking at your options.
Pat
Old May 4, 2007 | 12:35 AM
cpears's Avatar
Car: 1988 IROC
Re: More power!
I dont plan on swapping this motor out. Its only got approx 5,000 miles on it so I figure just hop it up. I have a 383 in my truck. I just am curious what I should run for a cam and valve springs and as far as heads that would really make this run strong. I plan on gettting an aluminum drive shaft soon. I already have alot of suspension mods done. I want to get this running low 13's all motor and still get decent gas milage. And hopes or ideas anyone?
Old May 4, 2007 | 09:13 AM
patgta's Avatar
Re: More power!
here is a link to a previous post about the topic;
https://www.thirdgen.org/forums/tpi/...-cam-89-a.html
hope this helps,
pat
Old May 4, 2007 | 02:18 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Re: More power!
im pretty happy with the cam in my sig. It sounds really good to me. People swear I have a 350. Buts its only a 305.
Old May 5, 2007 | 05:45 PM
cpears's Avatar
Car: 1988 IROC
Re: More power!
so if I put in a stock lt1 cam in it, do I need to put different valve springs in it? I have bone stock heads right now. Second question, are the 305 and 350 heads the same thing? I have head alot of people putting aluminum L98 heads from a corvette onto 350's bu can I do that with a 305? Could I use LT1 aluminum heads on a 88 305? Thanks for all the help. I'm a budget but I know how to work on my car so I'm trying to save a few $$$$
Old May 5, 2007 | 06:03 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
Re: More power!
i wouldn't use an lt1 cam with the tpi set-up it would be to miss matched
Old May 5, 2007 | 06:31 PM
cpears's Avatar
Car: 1988 IROC
Re: More power!
so what is the best recomended cam/ valve spring setup that people are using?
Old May 6, 2007 | 08:50 AM
patgta's Avatar
Re: More power!
I reseached the same topic when i was considering of swaping my current stock cam with a LT1 or LT4 cam (I have a 88 LB9 auto).
However the cam with your setup will be a mismatch like obeymybird has stated earlier. Basically where the LT1 / LT4 cam starts making power, your TPI setup runs out of breath.
And of course the LT1 / LT4 are older cams (10-15 year old technology) so there are better, more efficient new cams out that. That what some of the members have told me and come to think of it, they have a point.
Of course if you mod your tpi intake (SLP, Edelbrock, TPIS) or swap with a LT1 and do some head work or even swap heads. You will benefit from the LT1 / LT4 cam however like I said earlier there may be a better cam for your setup dont limit yourself to just one or two cams (check the comp cams website, they also have a database of articles that you may find useful).
Pat
Old May 7, 2007 | 06:55 PM
MARO-MAN's Avatar
Car: I've had 4 thrid gens!!
Engine: Someday again I will have another!!
Re: More power!
The 113 aluminum Corvette heads are a good match for the 305 with their 58cc combustion chambers. They are good heads to go LS1 hunting with.
Old May 7, 2007 | 09:06 PM
patgta's Avatar
Re: More power!
what does the "113" in the aluminum corvette heads mean???
Pat
Old May 7, 2007 | 09:24 PM
cpears's Avatar
Car: 1988 IROC
Re: More power!
113 corvette heads??? are they a direct bolt on? how about getting some are they hard to come by or pretty easy? and do you know about how much a good set runs? Thanks Clint
Old May 8, 2007 | 08:34 AM
MARO-MAN's Avatar
Re: More power!
113 Corvette Heads = L98 aluminum Corvette heads(TPI Corvettes). I believe they are also on the ZZ4 crate motor. I have seen a good used pair for about $500+. Shouldn't be real hard to find a pair, especially with the internet these days. -Nick.
Old May 8, 2007 | 08:53 AM
patgta's Avatar
Re: More power!
Are they a easy swap on a 88 TPI 305, what are the specs on them.
Pat
Old May 8, 2007 | 10:00 AM
MARO-MAN's Avatar
Re: More power!
Here are some pictures:
https://www.thirdgen.org/forums/engi...ette+heads+113
Another post on them:
https://www.thirdgen.org/forums/part...ette+heads+113
Do some searches and you should come up with everything your looking for. They are easy to install if you have experience pulling distributors, intakes, and of course heads. If I ever build my 305 up any more these are my next mod. -Nick.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
