Timing Problem - Please Help
Old Apr 18, 2007 | 06:42 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Hi Everyone,
My distributor is off a tooth and I haven't had time to adjust it. It is currently set about 12 degrees. I have to take the car to the exhaust place this weekend to get my header Y-pipes hooked to my exhaust. The computer seems to be trying to adjust the timing and this causes the car to surge up & down.
Someone told me that I should unplug the wiring harness from the distributor (until I get time to adjust it) so the computer can't adjust the timing.
My question is this: I've never heard of anyone doing that before. Is it a good idea and will it function OK without the harness hooked to the distributor?
Thank you!!!
Old Apr 18, 2007 | 11:59 AM
Re: Timing Problem - Please Help
bump
Old Apr 18, 2007 | 01:08 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
dont disconnect the harness from the module disconnect the single connector for computer advance
its a tan and black wire
to me this all sound a little DEE DEE DEE given the simplicity of moving the dist a tooth
Old Apr 18, 2007 | 01:20 PM
Thanks for the relpy, jamon8.
I'm not real familiar with distributor timing...
My mechanic friend said to pull the distributor up, move it clockwise about 1 tooth, then set it back in. He said it wouldn't go all the way in, so I'd have to hold it down and have someone bump the ignition. He said the distributor should then fall into place.
Does that sound right?
Thanks again!
Old Apr 18, 2007 | 01:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
To start with, why do you think your distributor is "off a tooth"?
Old Apr 18, 2007 | 02:44 PM
I tried to time the car and was able to turn the distributor to about 12* advance. I tried to turn the distributor further but it wouldn't turn. My mechanic friend told me that they only turn so far and it is probably off a tooth.
Old Apr 18, 2007 | 02:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You could turn the distributor around forever if the wiring and firewall didn't prevent it.
There's probably nothing wrong with it.
Old Apr 18, 2007 | 03:51 PM
Thanks for the reply Apeiron...
I will double-check the distributor and make sure the wires and firewall are not keeping it from turning. It could also be the new intake manifold I bought (TPIS BigMouth). Maybe it is shaped slightly different and hitting the cap?
Last dumb question If it is hitting the firewall or intake manifold, do I have to pull it out and adjust its position? Or is there a better way to adjust it?
Sorry again for the dumb questions, but I don't know alot about timing.
Thanks!
Old Apr 18, 2007 | 04:10 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Have you ever removed the distributor? If not, then it's not terribly likely that it's installed incorrectly.
Why are you trying to set the timing? Are you disconnecting the EST wire when you do it?
Old Apr 18, 2007 | 04:11 PM
Detroit_Z28's Avatar
Car: 91 Z28
Engine: L98 350
Transmission: TH350
Basically, if you can, avoid pulling the distributor to get the timing right. If you do have to pull it out, and move it's relative position to the motor, you'll need to know how to find #1 cylinder Top Dead Center in order to get the initial position of the distributor right. While not difficult, it is a little confusing if you havent done it before.
Old Apr 18, 2007 | 04:13 PM
I removed the distributor recently when I rebuilt most of my motor. Almost every part I put back on was new (heads, cam, runner, etc).
However, since I don't know much about timing, I asked my mechanic friend to help me put the distributor back in and he did.
Now I'm just trying to get the car back at about 8* or so.
Old Apr 19, 2007 | 09:52 AM
jamon8's Avatar
Engine: 350 tpi
you would have to have a super radical cam to need 12 degrees
have you located the est wire connector- it should be a tan and black wire
Old Apr 19, 2007 | 05:01 PM
I am going to the garage tomorrow morning to try and figure out where that brown cable w/ black stripe is at. If I can find it, I will unplug it and see if it idles better.
Does that cable plug into the back of the distributor? From memory, I remember there are two connectors that plug into the distributor base. One is from the coil, the other goes into the wiring harness.
Thanks!
Old Apr 19, 2007 | 05:41 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
ok dumb question but im doing a tune up on my car and replacing spark plugs wires cap rotor etc.... but how do you physically turn the cap to fix teh timing?
Old Apr 19, 2007 | 05:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, don't do that. Unplug it and set the timing, then plug it back in.
Loosen the distributor hold down bolt and turn the entire distributor body.
Old Apr 19, 2007 | 06:10 PM
Bobby_80s's Avatar
Axle/Gears: no idea
ok i must have a different cap then you guys. there arte 4 bolt/screws holding the cap down. i have a 5.0 v8 tpi automatic 305 trans am 1986
Old Apr 19, 2007 | 06:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Forget about the cap. You're turning the entire distributor to set the timing.
Old Apr 20, 2007 | 10:41 AM
jamon8's Avatar
Engine: 350 tpi
Apeiron where is the timing connector on formula_novice's car
I have a painless harness and my connector is by the computer
Old Apr 20, 2007 | 10:54 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It'll be coming out of the distributor base.
Old Apr 20, 2007 | 01:03 PM
I was able to find the brown/black wire and disconnected it. Then I found out there were wires that were keeping the distributor from turning. I re-arranged the wires and it now turns. The timing is now set to 8 degrees.
However once I turned the motor off, I hooked the brown wire back up and decided to just look at where the timing was at. The timing jumped from 8 degrees to about 12 - 14 degrees. Why would the computer advance it so much? Is this normal? FYI - I made sure I didn't bump the distributor when I tightened it down.
Thanks!
Oh, I forgot to mention... I don't have the Y-pipes hooked to the exhaust at the moment. I have an appointment to get that done today. Would the lack of back-pressure cause the timing to be off?
Thanks again!
Last edited by formula_novice; Apr 20, 2007 at 01:04 PM. Reason: Automerged Doublepost
Old Apr 20, 2007 | 01:06 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, the ECM will advance the timing when the EST wire is reconnected. That's why it has to be disconnected to set the timing.
Old Apr 21, 2007 | 07:16 AM
Thanks for the info Apeiron.
The timing is now exactly 8 degrees and the exhaust is hooked-up. However when I turn the key to start the car, the distributor still 'clicks'. On the 3rd click, the car starts right up. Does the 'clicking' mean 8 degrees is not correct?
Thanks!
Old Apr 21, 2007 | 10:45 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, the clicking wouldn't have anything to do with the timing. It's hard to say what would be causing it to click.
Old Apr 21, 2007 | 10:56 AM
Bobby_80s's Avatar
Axle/Gears: no idea
starter might be clicking? check your battery and starter connections it might be arching.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
