Accel vs Ford Injector question... Injectors length?
Old Apr 25, 2007 | 09:55 PM
BigBoi4Lyph's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
So i was doing some research as my injectors are fried..015 .017 .007x5 and one was .003So i did some research and accel has a #23 injector 1lb per hour bigger then mineIve been reading the ford injectors are shorter then stock injectors.I looked on summit racing and accels are 2.880 and fords are 3.0---- Im confused are accels even shorter then ford injectors?
Old Apr 26, 2007 | 11:20 AM
Guest
Guest
Posts: n/a
Re: Accel vs Ford Injector question... Injectors length?
Either will work but there have been numerous complaints about the Accel injectors. I'd stay away from them.
Old Apr 26, 2007 | 12:00 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
hmmm , i was under the impression the accel were good, im looking to get a new set or a good used set.
Old Apr 26, 2007 | 12:26 PM
Rayvan's Avatar
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
I'm using Accels. Car runs/performs great, but it's just a little harder to start after a hot soak.
They *were* shorter than stock, but they fit.
Old Apr 26, 2007 | 05:21 PM
Car: 89 Iroc
Engine: 5.7 TPI
thanks for all the respo nds ive decided to go with ford pink tops 269.99 from five0racing. my injectors are fried.
14.--
15.--
17
and a 0 my #8 cyl injector is shorted lol
this explains my surging idle and a miss at cruse and minor backfireing
Old Apr 27, 2007 | 01:41 PM
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
how do you check them like you did.
Old Apr 27, 2007 | 07:41 PM
Car: 89 Iroc
Engine: 5.7 TPI
you use a DVOM Digial volt ohm meter. and you put the unit on Ohms its like a horseshoe looking symbolThen you just unplug your injectors wiring from it and their will be 2 male pins sticking out of the injectos put one lead from the dvom on each pin at the same time and you will get your injectos ohms reading.anything below 12 is bad 0 is really not good its a shorter injector.if you get a reading like .008 or .015 your meter is on the wrong sub setting.
Old Apr 27, 2007 | 08:31 PM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
I've got a brand new set of 26# ACCEL injectors collecting dust and their replacement 30# Ford SVO injectors under the hood. The motor wouldn't run with the ACCEL's. They're total garbage.
Old Apr 27, 2007 | 08:57 PM
survival's Avatar
Car: 1989 Firebird GTA
I've been using the fiveo pink tops for over a year with no problems!
Old Apr 27, 2007 | 10:39 PM
Car: 89 Iroc
Engine: 5.7 TPI
hey so that five o is a trusted site? Im going to be ordering some pink tops on the 9th Their the 269.99 ones on the ford injector page correct?Is says like set of 8 *pink tops
Old Apr 28, 2007 | 05:53 PM
survival's Avatar
Yeah Five o is ok.You want the 22lbs injectors.They may have changed the color of the tops,I couldn't find the pink tops on thier site but the 22lbs are what you need.
Old Apr 28, 2007 | 09:13 PM
Car: 89 Iroc
Engine: 5.7 TPI
yea ima call them and make sure im gettin what i want before i go paying for stuff ahaha... i just started my new job so im making bank now and ill be able to start gettin my car back to pristine condition
Old Apr 28, 2007 | 09:39 PM
survival's Avatar
Cool,good luck.
Old Apr 28, 2007 | 10:46 PM
Car: 89 Iroc
Engine: 5.7 TPI
thanks
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
earlpote
Sep 12, 2015 11:55 AM
Keiffer76
Sep 9, 2015 08:52 PM
Ranbo108
Sep 9, 2015 12:20 PM
