pulling codes..doesnt seem to be working
Old May 7, 2007 | 09:02 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Hey all. I just tried to pull codes on my 86 iroc but the check engine light wasnt even registering that i had grounded the diagnostic wire. It is supposed to flash code 12 right? I didnt even get that..all i got is my fan turning on.
Old May 9, 2007 | 11:19 AM
subroc's Avatar
Engine: 355 TPI
Re: pulling codes..doesnt seem to be working
Anyone?
Old May 9, 2007 | 11:53 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
are you jumping the top two connectors ( A, B ) ? ...top level ...all the ay to the right ...them two connectors .
Old May 9, 2007 | 12:50 PM
subroc's Avatar
Engine: 355 TPI
yup those are the two i was jumping. Nothing happened with my check engine light so i thought maybe it was burned out. I replaced the bulb and same thing..radiator fan turned on when i jumped the two (A and B) but nothing else.
Old May 10, 2007 | 02:21 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
I am no expert on this so ...don't rush out and do anything K .
No code 12 has ment on here that the ECM is shot. What I would do next is swap it for another ECM and see if that cures the problem
Old May 10, 2007 | 04:22 PM
subroc's Avatar
Engine: 355 TPI
hmmm that would be wierd cause i just put a reman one in about 2 years ago along with a new updated chip. Ill look into it before replacing. Thank you for your help.
Old Jun 2, 2007 | 08:39 PM
subroc's Avatar
Engine: 355 TPI
bringing it up from the dead since i have time to fool around under my hood. What would cause a computer to fry? Something improperly grounded i assume?
Old Jun 2, 2007 | 09:26 PM
82CAMAROBBC's Avatar
Car: 1982 Camaro
Engine: 454
Transmission: TH350
Axle/Gears: 410
Check the ECM fuse.. Check that first. Also voltage spikes from voltage regulator, clean connection on your Batt. Have you modified anyting lately? You could have put a screw threw some wires.
Old Jun 3, 2007 | 05:46 PM
subroc's Avatar
Engine: 355 TPI
I havent modified anything lately so it shouldnt be a wiring problem. The voltage regulator is fine if i can trust my volt gauge. Im going to look at the ECU fuse and see if its blown.
Old Jun 3, 2007 | 06:40 PM
subroc's Avatar
Engine: 355 TPI
Ok just checked the fuses and they are all good..including the ECU ignition fuse. I dont know if i said this before but the car does run and drive but it has some problems that i originally thought were MAF related but now am not so sure.
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 26, 2015 04:59 PM
ZONES89RS
South Central
Aug 14, 2015 09:07 PM
