Mini-Ram on a stock car?
Old Sep 12, 2000 | 03:29 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
TPIS claim there mini-ram will give you 95+ HP on a stock tuned port at 5200RPM. Has anyone tried this on there stock car, was it worth it and did it improve your 1/4 times.
89 GTA 350 5-speed
Jet hot coated SLP headers,flowmaster force 2,no cat's,SLP cold air,MSD 6al,jet chip stage 2,march pulleys,ported plenum,air foil,B&M ripper shifter,180 stat,alston SFC,spohn LCA relocation brackets,MAT relocation kit,free mods.
0-60 5.48s
E.T. 14.02@98.9MPH (corrected)
Old Sep 12, 2000 | 08:34 AM
Bill91Z
Guest
Posts: n/a
Be careful with this statement, a lot of people get tricked by this. First you must keep in mind that the STOCK TPI runs out of air at like 4500 rpm, there is no making power after that, in fact the poower output starts to drop dramatically. Miniram is designed with very short runners and the ability to breathe very well at higher rpms. So at 5200 rpm when a stock TPI is pumping out 110 hp (made up numbers) the miniram is still pumping out 205hp, still not more than the peak HP of a stock motor, but at that rpm, it is in fact 95hp more than the stock. Peak vs Peak on a stock motor you may be looking at 15 hp. As for puting this on a stock motor, I have a friend who did this with very little low end loss and still ran a 14.3 in the higher 90mph range. It's a myth that when bolting on this unit you will lose a lot of low end. Very little is lost if any. My friend went to the track last week, but I have yet to hear his times, I will update when I hear from him. Keep in mind his car is bone stock except for an exhaust (no headers).
-Bill
-Boston Chapter ICON Motorsports-
91Z28, (in progress) 3.8L, TE63-1 turbo, MSD50lb injectors, Hemco upper, ported TTA heads, 62MM TB, Red's XP fuel pump, 3.73s, vigilante (stall to be determined)
Old Sep 12, 2000 | 10:38 AM
Matt98SS's Avatar
think about it like this though, the TPI cars have SOOOO much low end TQ that you can afford to give some up...look at LT1 and LS1 cars...less low end more top end....sure they got better heads...but I figure if you are going miniram...heads and cam must be in the works...
I don't really see a problem with just bolting it on. The stock cam and heads are pretty ****ty but like Bill said his buddy put it on and IMO runs right were a stock one would run if not quicker. Would have to do a before and after test.
Old Sep 13, 2000 | 04:42 PM
90Iroc's Avatar
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Transmission: Borg Warner 5 speed
You have to look at the specs either in the catalog, or on the web page for their "stock" TPI. It isn't really stock after all, it's a 383, with ported runners and base and the like.
Old Sep 13, 2000 | 05:01 PM
Tony89GTA's Avatar
Car: 89 GTA
I got my numbers from TPIS's book called (TPIS insider hints), and on page 21 chart N they show a stock 350 TPI 1985 corvette engine produce 311HP at 5250 RPM with the mini-ram while the stock system produced only 216HP at the same RPM.
Old Sep 14, 2000 | 03:07 AM
90Iroc's Avatar
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
In their catalog, it gives the parameters of the engine at the top of the chart. It lists a 383 TPI system with Airflow heads, TPIS Big Mouth Manifold, ported Plenum, 58 MM throttle body and a modified Mass Air sensor. Then at the bottom of the chart it will say Stock TPI. Well forgive me if I'm wrong, but I don't think that a stock TPI puts out 448.8 lbs of torque @ 3750 RPM and 336.6 hp@4250 RPM. (Page 63 of catalog). I'm not trying to be argumentative or anything, just conveying my $.02 of what they call stock. Do you see what I mean?
"Clear your mind, relax, and float downstream."
Old Sep 14, 2000 | 04:14 AM
Tony89GTA's Avatar
Car: 89 GTA
90Iroc where talking about two totally different engines. Back in the 80's TPIS did a test between the stock 350 TPI system vs 750 Holley carb & manifold vs the TPIS Mini- Ram to see what kind of numbers they could get. This was all done on a stock 85 350 Corvette motor with 1 7/8 dyno headers.
You should get the book is got a lot of good information in it.
Old Sep 14, 2000 | 07:25 AM
blak92!'s Avatar
Save your money. That book just propagates their products. Get the catalog instead, 90% of the info in that book is already in their free catalog. If you want to spend money o some literature get Lingenfelters book http://www.amazon.com/exec/obidos/AS...250235-9052860
and this book: http://www.amazon.com/exec/obidos/AS...250235-9052860
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
camaro71633
Sep 1, 2015 10:24 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
Exxon Limited
Aug 9, 2015 08:13 PM
mustangman65_79
Aug 8, 2015 01:18 AM
