Anyone using ford injectors?
Old Sep 11, 2000 | 06:33 PM
Platinum's Avatar
I have some 19# in the mail and was wondering if anyone else is using them.
85 Z/28
Mods: Flowmaster's,Cam,Hypertech Chip
Old Sep 11, 2000 | 07:43 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I Have a set of 30lb injectors coming this week from summit. At 209.00 a set you cant beat them They are made by bosch.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Sep 11, 2000 | 09:00 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
24#er's are the most I would order unless you have a SERIOUS engine you're putting 30#er's on .... 24#er's are a bit much for a stock engine ...
Old Sep 11, 2000 | 10:02 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
ive installed them on a formula 350 (the #24 lbers)
they are a little shorter than the stock ones so youll want to use the upper groove on the top of the injector to locate the locking ring
Old Sep 11, 2000 | 10:03 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
btw youll also want to note that they are rated at 38psi(?) i think.. and most tpi systems run a little more pressure so youll actually be flowing a little more
Old Sep 11, 2000 | 10:33 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Pablo is correct. 24lb injectors really flow 26lb/hr according to GM standards. The 30lb injectors flow 33lb/hr according to GM standards.
I am running 30lb/hr injectors on my MiniRam motor and she idles like a kitten and runs great!
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.587 @ 107.97mph (1.710 60ftr) on the long runner setup.
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels. Stock Wheels. No Weight Reduction.
Gunning for NA 11's with the MiniRam II and Hooker LT Headers.
-=ICON Motorsports=-
Old Sep 11, 2000 | 10:35 PM
TRAXION's Avatar
I should point out that the reason that my car idles and runs so well with 30lb injectors is due to the PROM tuning I have done on my car. If you are interested in burning your own PROMs just visit the PROM burning board.
Tim
Old Sep 13, 2000 | 08:10 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I have the 36 lb./hr injectors in mine. The fit without problems.
Old Sep 15, 2000 | 10:20 AM
ScreaminDeamin85Z's Avatar
i have the 19's on mine and they work fine, i just bumped the fuel pressure up.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 19 lb SVO injectors, crane AFPR
Old Nov 20, 2007 | 04:33 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: Anyone using ford injectors?
I'm running the Bosch/Ford 19# injectors on a 305 TPI, and it runs great, maybe little better than the original 85 stockers. At least, by my butt-o-meter.
I have a set of the same 24# injectors to go in my Miniram III project. Not fired up yet.
The Bosch injector is supposed to have a better spray pattern.
Old Nov 21, 2007 | 07:22 AM
87_gta's Avatar
Car: 87 GTA / 87 IROC-Z
Engine: 350 TPI / 350 TPI
Transmission: 700R4 / 700R4
Axle/Gears: Stock
i am using the #24 injectors i find they work really well, runs better with them and a noticeable difference while driving IMO i found they were a tad shorter than the stock injectors but just make sure their seated properly.
Old Nov 21, 2007 | 10:52 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Running 30# with no problems. They are a good injector.
Old Nov 21, 2007 | 11:51 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
About the time this thread was created, I had some ford #19's in my dakota. When I sold it I pulled them, later put them in my 3.4l camaro motor.
They are now sitting on a shelf since one got plugged and 19 isnt enough for a 350 TPI.
Old Nov 21, 2007 | 07:06 PM
TransAmman87's Avatar
Car: 90 Trans Am
I am running 19#'s on my 305 TPI and have actually noticed a decrease in feel of the strength of the engine. I was told that the Ford injectors flow a little less fuel than the stock injectors from one of the guys at JEGS, SUMMIT and a engine builder in my hometown. I even did a fuel pressure test and found PSI dropped to around 35psi. I want to get a fuel pressure regulator but have been hearing bad things about them from a manufactoring standpoint (they have been leaking fuel and causing fires). I don't know, ACCEL is going through a new manufacture for their injectors and I was not able to pick those up due to needing to have my car running. The Ford injectors are very good in my opinion and but they do flow a little less. Just throwing in a personal experience.
Old Nov 21, 2007 | 07:11 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Got 24#lbs in my 350,work great.Also bumped up my fuel press.
Old Nov 21, 2007 | 09:02 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
ordered and have 30# SVOs for my 500hp HSR 383 ready to go in
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Veaceonee
Sep 29, 2016 08:15 PM
92-Formula
Dec 12, 2015 10:34 PM
