POLL: What is everyones base timing set to
Old Sep 16, 2000 | 09:55 AM
Kevin G's Avatar
I have seen some big differentces in peoples base timing.... I just like to see what everyone is running and what mods have been done.
I personally had a 383 L98 with ported TFS heads, Lingenfelter. 219, 219 cam(straight up) and superram. For the life of me, I couldnt go past 8 degrees base timing or would get serious pinging and lose uper rpm power.....
Old Sep 16, 2000 | 10:54 AM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
I run 8-10. I don't recall now which, but I would have to look at the timing mark to recall.
I am running Edelbrock 6089 (64cc) heads and have a static compression ratio of 9.75:1. Premium gas. No pinging.
Although, I live at 2400 ft altitude, so that is a big difference.
I don't recall ever hearing a ping, but a scan shows the knock count, so it must be working.
What compression ratio are you running? What Prom?
Mark.
Old Sep 16, 2000 | 01:33 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Timing set to 6º BTDC but then I have it adjusted via the MSD adjustable timing control to 9º BTDC.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.587 @ 107.97mph (1.710 60ftr) on the long runner setup.
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels. Stock Wheels. No Weight Reduction.
Gunning for NA 11's with the MiniRam II and Hooker LT Headers.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Sep 16, 2000 | 03:15 PM
quickL98's Avatar
Car: 87 trans am GTA
Engine: tesla permanent magnet
Transmission: 93 T-56
Axle/Gears: moser 12bolt w/ 3.73
mines at 10 degrees
87GTA 355TPI,A4 shooting
for low 12'
Old Sep 16, 2000 | 05:15 PM
IROCKZE's Avatar
Car: 85 Mercedes 500SEL
Engine: 5.0 DOHC
Mine's at 10, but I live at 5500ft. I wonder if 12 or more would work? I do run premium....
85 IROC,tpi,t-tops,fully loaded,black with red l/s "camaro" interior,91 Bose system, Fastchip,TES,AFPR,K&Ns,92 police 700r4
"The devil drives a Camaro"
Old Sep 16, 2000 | 10:01 PM
FJK's Avatar
FJK
12 degrees, 88GTA, 5.7L, no mods except 200F coolant sensor, 89 octane fuel
Old Sep 17, 2000 | 03:20 AM
Fredzep's Avatar
Car: 90 GTA
Transmission: TKO
Axle/Gears: Stock
8-10 on my L98 w/76cc Heads. I haven't really tweaked it yet (<2K on Motor), but I think it is close to there.
Fredzep 90 GTA 350 5spd
Old Sep 17, 2000 | 11:17 AM
kream-'s Avatar
mine is set to a max of 2 degrees btdc...
here in wichita kansas we only have 91 octane...
not to mention my stock tpi is strangling the zz4... and i dont have an afpr...
hopefully when i get those two things straightened out i can bump it up a bit more
17 from Wichita, KS (previously newbieZ28)
1988 Iroc-Z ZZ4 tpi, ttops, 50k miles on chassis (edelbrock tes, stock tpi) free mods etc coming soon after first 1/4 times!
1985 Z28 LB9 option [STOLEN!] Click here to see
http://thirdgen.bawx.org
K.I.S.S - Keep It Simple, Stupid.
Old Sep 17, 2000 | 04:44 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
12 degrees BTDC. Edelbrock heads, 60cc chambers. No problems running 93 octane. I'm pretty sure my pistons are dished 4cc's.
How did Tim get his computer to make the little degree thingie?
Old Sep 17, 2000 | 08:46 PM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
Mine is at 0 degrees. When I was at 6 degrees I ran a best of 14.2... then I dropped it down to 0 and it ran a 13.8
Going up in timing just made it worse...
0 degrees initial = 36 total at 3000 rpm's
Sportsman II 72 CC heads, Pete Jackson gear drive, Performance Resources chip, Edelbrock 1 5/8" headers and Edelbrock cat back exhaust, hi-flow cats, Trans-go stage 3 shift kit, Vigilante 9.5" 2800 stall convertor, SLP cold air induction, SLP roller camshaft, 24lb ADS injectors, AFPR, 3.45 rear end gears, and other goodies...
Old Sep 19, 2000 | 09:29 AM
Mike89GTA's Avatar
8*, what Ed Wright recommended
4 bolt 350, 10.4:1 Compression, Edelbrock Aluminum Heads 6085, LT4 Hot Cam /w 1.6 full rollers (Crane), Scat Crank, SLP 1 3/4" Headers, SLP Cold Air Intake, Crane AFPR, 48mm TB, ported plenum, stock runners, Accel Super Ram intake manifold, 95Z #24 injectors, stock fuel rails, T5 Tranny, 3.45s, 9 bolt rear, 4 wheel discs, BFG Comp T/As rear, SZ50s in front, Alston SFCs, ES Trans Mount, ES front A-arm bushings, ES front sway bar end links
Old Sep 19, 2000 | 12:17 PM
90IROCK's Avatar
im running 13 degrees, my mods are chip, exhaust, and afpr
Old Sep 19, 2000 | 12:50 PM
Lounge Lizard 6's Avatar
8* BTDC w/ZZ4, ported TFS G1 heads, Crane 2032HR 214/220 cam, chip, 24# inj's, TPIS Bigmouth, ported plenum and SLP runners.
Mike
'90 IROC-Z, 5-speed, ZZ4, Trick Flows
Moderator SEThirdgen
Old Sep 19, 2000 | 01:01 PM
P J Moran's Avatar
Car: Used to be an '87 IROC
Engine: 5.7l TPI
Axle/Gears: 3:23?
I'm running Edelbrock heads on a new short block. I've determined the CR to be nearly 10.0:1. I've backed off my timing from 10*, to 8*, to the current 4* and I still get some detonation (I think it's lessening, though). I guess I'll keep backing it off until it quits. How far can I go? Should I have to go this far? Could my ADS chip be causing the problem? I think I still have my original chip, should I try plugging it in to see what happens?
'87 IROC 5.7l TPI - original owner!
Old Sep 19, 2000 | 03:49 PM
Ed Z28 350's Avatar
I'm new to these boards (and message boards in general) Anyway, I run mine at 10 degrees. I live in Miami and run 93 octane with no pinging.
1986 IROC, 1992 Body Kit, 1989 5.7 IROC Engine, Crane Cam, CVX Exhaust, ADS Superchip, 24# FoMoCo Injectors, !Cat, 3:42 Gears, Modded MAF & Airbox
Old Sep 19, 2000 | 05:07 PM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
I run at 10 degrees with no problems, I've tried 8 and below with no good effect.
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed
Old Sep 19, 2000 | 10:26 PM
Mark 89Formula's Avatar
Kevin, I think the real question is how much total timing people are running, not base timing, where total timing is the BASE TIMING + PROM ADVANCE. Unless everyone is running the same PROM timing curve, comparisons are apt to be meaningless and potentially misleading.
For instance my custom PROM commands a maximum of 30 degrees of advance at WOT. Add my base timing of 6 degrees and you get 36 degrees of total timing. FWIW, I've run @ base timing values of 4 and 8 degrees on a Dynojet and lost power compared to 6 degrees.
My car likes 36 degs total timing with the current heads, cam, and intake. Yours might like something different.
89 Formula 350, Accel Tri-Ys, 3" SLP, chip, Jacobs, SLP cold air, Probuilt tranny, Vigilante, 3.27s, Spohn torque arm & LCAs w/brackets, GW Subs
Old Sep 20, 2000 | 01:06 AM
Alpine406's Avatar
im running like 44 or 45 total timing
id have to hook up the laptop to fond out for sure.
it varies with the dfi to RPM, but its 43, 44, 45 all over.
i got afr 190 w/65cc, superram, 224-236 @ .050 525 LIFT
runs fine on 89 and up gas.
goes 12.70`s and better on e.t. streets or slicks on motor
Old Sep 20, 2000 | 09:41 AM
Kevin G's Avatar
Hey, thats a very good point Mark.
Old Sep 20, 2000 | 12:04 PM
raven350's Avatar
Engine: 5.7L
I agree with Mark.
My Performance Resource chip has 36 degrees into it. So I ahd to set my timing at 0 degrees to get my total of 36 degrees at 3000.
Worked like a charm...
Old Sep 20, 2000 | 07:14 PM
DownUnderIROC's Avatar
I set my base timing by doing some test runs with the AutoXray scanner, and looking at the amount of retard (degrees) from the knock sensor. With 6 deg base I was getting 5 to 7 deg of KS retard, at 8 deg it was worse. BTW I am running 92 octane R/M fuel.
I backed it off to 4 deg, and now I am seeing only 1 or 2 degrees of KS retard. This gives me the highest TOTAL timing, around 35 deg TOTAL at WOT.
1987 Chevy Camaro IROC-Z
1998 Ford Falcon XR8
My IROC-Z in Sydney, Australia.
Thunder Down Under home page.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
