More Power!
Old Jun 4, 2007 | 12:20 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
More Power!
What can I do to get more power. I am going to save up this summer and try to get more power out of my engine. I am not afraid to change my mods. I just want to see some power gains to get me into the low 12 without any power adders. I would like to beat my uncles Ls2 powered '94 Rx7. Let me know what I should do to get alot of power gains. Remember that I am in Cali and have to pass smog. Thanks Guys. Mods are in my Sig.
Old Jun 4, 2007 | 12:40 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Re: More Power!
Man w/o power adders? With all the stuff you got i don't think you can get any huge gains like you would with nitrous or a supercharger. I would upgrade to 58mm TB, and 1.6 roller rockers, and some open longtubes. Whats your rearend gearing? Maybe some ladder bars or something too.
Old Jun 4, 2007 | 12:50 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Re: More Power!
Are you running stock pistons? I'd think that would be the next big change for you.
Seems to me that you might need more fuel with your current setup.... 24lb. injectors are probably maxed out at WOT.
The 2032 is not as high lift as I 'd think the Trick Flows could handle. 1.6 Rockers may be a wise choice.
Get an Ostrich/TunerPro RT and tune the engine yourself!
Old Jun 4, 2007 | 05:26 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: More Power!
Pistons aren't stock. I have a zz4 clone short block. I was thinking about a 100 shot, but I would like to get my car into the high 12's or so, and then spray into the 11's.
Old Jun 4, 2007 | 09:47 PM
blazed's Avatar
Car: 1986 IROC-Z
Engine: 5.0L 305ci
Transmission: 700r4, shift kit
Re: More Power!
Without power adders and having to pass emissions is going to be hard.
Old Jun 4, 2007 | 10:45 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
Re: More Power!
What kind of times are you posting with what you're running right now?
Old Jun 4, 2007 | 11:22 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: More Power!
I am really hoping for high 12's, but I think it will put down a 13.2 or so.
Old Jun 5, 2007 | 12:52 AM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Re: More Power!
what about emissions, theres ways around this my iroc isnt smog legal doesnt mean i still can get registrations, only bad thing is every 2 years i have to pay a bundle have it passed, just wondering what would hapen if a cop ever opens the hood and finds no smog hardware, but what are the odds of that,
Old Jun 5, 2007 | 02:37 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: More Power!
well, here in chico, every friday and saturday night, people go out and cruise. if a cop thinks you are a street racer or have a modified car, he will tell you to pop your hood. So everything on my car is legal.
Old Jun 6, 2007 | 10:38 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Re: More Power!
I dont think it matters as long as you can pass the emissions test
Old Jun 7, 2007 | 12:22 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: More Power!
Yep. I have all the carb #'s and I passed smog. So I am good to go!
Old Jun 7, 2007 | 11:14 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Re: More Power!
Why dont you want to use power adders? A pro charger or nitrous would show a significant gain in power w/ reasonable cost and work.
Old Jun 8, 2007 | 09:10 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Re: More Power!
you have no need for a 58 mm TB . Your 52 mm will do anything you need in a N/A setup
Old Jun 9, 2007 | 01:13 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
Re: More Power!
turbo+intercooler=holy **** batman!!!!
Old Jun 10, 2007 | 12:44 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: More Power!
What do you guys think the car will run on a good tune? Also, what could I do with a 100 shot at the wheels?
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
