Best after market TPI intake
Old Sep 11, 2000 | 11:05 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Like the subject says which is the way to go or is the stock good enough. Look at heads, cam, and what else do you think.
87 Z28 305 TPI, Auto, Gutted air boxes, K & N fillters, Dyno Max 3" cat back.
Old Sep 11, 2000 | 11:10 PM
Bill91Z
Guest
Posts: n/a
A stock lower intake can be ported to flow more than an aftermarket base, it is when you take an aftermarket base and port that when you get bigger gains. Stock ported or aftermarket is fine for most apps. Edelbrock is probably the best one out there for price and quality. TPIS sells one that is already ported and leaves room for more porting, but you are looking to spend some good money. Best runners out there are AS&M/TPIS LTRs hands down. Heads? best bang for the buck, could be the edelbrocks. Don't know much about the new TFs but have been hearing good things about them. Cam, well, that's all up to you and how far you want to go. You have an auto so you want to look into TCs, one of the best mods you could do. Are you keeping the 305 or going bigger?
-Bill
-Boston Chapter ICON Motorsports-
91Z28, (in progress) 3.8L, TE63-1 turbo, MSD50lb injectors, Hemco upper, ported TTA heads, 62MM TB, Red's XP fuel pump, 3.73s, vigilante (stall to be determined)
Old Sep 12, 2000 | 08:55 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
i keep hearing GREAT things about the factory production vortec heads..flow just as much as the e-brocks for A LOT LESS. There is suppose to be a TPI manifold coming out for these heads....it will kinda set up like the e-brock base..i think i'm going with this setup when i do my engine rebuild
89 GTA 350 TPI(L-98)Fiberglass "Daytona Turbo" hood K&N filter air foil Stage 2 Fastchip B&M Stage 2 shift kit Flowtech shorty headers SLP 3'' exhaust Cams HI-6S igntion with PS-91 coil MacEwen white gauges overlay's SLP rear sway bar Koni's all around and one kick *** stereo!
Rice....it's whats for dinner
You can see a pic of it by going here:
http://www.hometown.aol.com/clarkemustgonow
Old Sep 12, 2000 | 11:11 AM
Matt98SS's Avatar
I would keep the stock stuff for now on your 305 and just port it....not gonna be a performance factor yet...
I would look into cams like the ZZ3/4 or the ZZ9, LPE 211, etc for a 305 car.
as Bill says a Vigilante Torque converter will really wake the car up
Old Sep 12, 2000 | 08:11 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
I'd like to stay 305 with this car see what it can do.
Old Sep 12, 2000 | 08:18 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
If you had a 350 I'd push for an intake upgrade, but for a 305 I feel that the stock pieces will work just fine. Remember, the problem with the 350 TPI intake design is...well, it wasn't designed for the 350, it was designed for the 305. GM just took the 305 intake, got slightly larger injectors, and threw it on the 350 as sort of a last minute kind of thing. But, since you haver a 305, the intake was designed for your engine and you don't have to worry about any of this.
If you're looking to spend money do it on the exhaust side. Or do the Vigilante thing, it's an awesome product.
Old Sep 12, 2000 | 09:03 PM
Monkie's Avatar
I would give Lingfelter a call!
Old Sep 12, 2000 | 09:37 PM
Kevin G's Avatar
Vortech heads are a great value, but flow 10-15 cfm less than Edelbrocks on the intaske side @ .500 lift. That is a pretty big difference.
Also, the Vortech castings are real thin, and not much room for port work. But for the price, they are great.
Old Oct 2, 2000 | 04:04 PM
Ragtop Man's Avatar
For a stocker 305, skip the big heads. Won't fit, won't work, wait until you can swing in a 350.
All the posts about waking up a 305 are right on ... the factory cam is a peanut, the exhaust is corked, the tc is too tight, the chip is conservative ... unhook these clips on the factory supplied F-Car chastity belt and you can really have a good time.
There is (or was) a good section in the archive about "steps to hop up your thirdgen" Most of them are cheap and reasonable. Try them first before you lay out the big dollars (probably have to do most of them anyway!)
Good luck,
Bob
'87 Formula TPI 5-speed
Old Oct 2, 2000 | 08:42 PM
Jason M 91Z's Avatar
As everyone said, trying to get more air into that 305 than it will conceivably take isn't going to heed any positive results. Either way you're going to realize that your bottleneck is the heads or the lack of displacement. LTR's, ported plenum and ported or aftermarket base are plenty for a 305 that isn't seeing over 6K.
Even still, a 350 with a somewhat mild head and cam combo will spin to 5500-6K with that setup. If you're striving for more HP throughout the range, then a RamJet or Superram/miniram would be in order but ONLY ON A HIGHER DISPLACEMENT MOTOR! On your 305, it'd be nothing but a waste of aluminum and bloody knuckles. You could spin to 7K and still make power, but you'd be floating the valves and rocketing the crank by then anyway. Systems approach is how you win races.
-Jason M. 1991 Camaro Z28
"Allow me to introduce myself my name is Mud."
1992rs/ss
Jan 31, 2025 05:10 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
masonta
Aug 31, 2015 10:14 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
