fuel pressure
Old Jun 13, 2007 | 09:34 AM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
fuel pressure
Ok,this will hopefully be the last post for awhile. I am not sure what i should set my fuel presure at, i put a new adjustible regulator on it. My motor has vortec heads,headers,edelbrock hi flo intake,big mouth runners,flowmaster3in, a chip,ram air, and a msd 6al box.I don`t think it would matter but i am also running 3.73`s
Old Jun 13, 2007 | 11:38 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Re: fuel pressure
somewhere around mid to high 40's psi . You will have to do some trial and error to find what works best for you ( dyno )
Old Jun 14, 2007 | 01:59 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Re: fuel pressure
Stock fuel injectors? Start with 46-47 PSI.
Old Jun 14, 2007 | 07:50 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: fuel pressure
Chip???
I would have to agree with these guys. Scanning it would also tell you what you need.
Old Jun 14, 2007 | 10:35 AM
jaysfs's Avatar
Transmission: t56
Re: fuel pressure
i am currently at 47 psi, and it`s just a junk hypertech. I need to get one burnt
Old Jun 14, 2007 | 08:44 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Re: fuel pressure
? i also have hypertech chip that was set to a 305 i've since dropped in a 350 so im right about to send in my hypertech to get reprogrammed to 350 stats. why is hypertech junk, should i even waste the money in having my hypertech chip redone or what would be a better a option
Old Jun 15, 2007 | 05:55 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: fuel pressure
All they do is change a couple of minor things. A ballpark guess. Add a little spark advance. If you're lucky they'll change a little in the fuel tables. All in all not much.
You should burn your own. This way you can make it custom to YOUR engine and not just have a chip that'll kinda work for 100's of engines. Your engine likes what it likes. Doesn't mean your engine and combo is gonna like exactly what Joe Public's engine likes.
See what I mean?
Old Jun 19, 2007 | 10:41 AM
Steve89GTA's Avatar
Re: fuel pressure
Are the pressure numbers above given with the vac line disconnected from the regulator with the car at idle?
Old Jun 19, 2007 | 11:27 AM
mnorton's Avatar
Engine: 305 LB9 TPI
Re: fuel pressure
Yes, you'll want 46-47 psi with vacuum disconnected at idle.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
