Help Need to get my car RUnning Normal!!!
Old Jun 23, 2007 | 02:45 PM
PONTlACSpeed's Avatar
Car: 1989 GTA
Engine: 5.7
Well so far i changed the fuel filter, fuel pump relay and the ignition module, and still have the same problem. it will start if given starter fluied but if u bring the rpms too high while driving the car just dies. I have noticed ive heard a very subtle poping noise coming from the vacinity of the distributor and it gets more noticable the more gas u give it, could the distributor be the cause of my problems?? i dont see how but if anyone knows l could use the help thanks
Old Jun 24, 2007 | 04:21 PM
Car: 1989 GTA
Engine: 5.7
Re: Help Need to get my car RUnning Normal!!!
No one can help?????
Old Jun 24, 2007 | 04:51 PM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
I had the same problem with my GTA, but I had to recently replace the engine because of rod bearings. So, I never found out what the problem was, but it hasn't done it since. Good luck I'am kind of curious what it was. Just to add, the only way I got it started was by starting fluid in air intake also.
Old Jun 25, 2007 | 10:22 PM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
could it be slop in the dist gear. If the timing was going all over the place, it would make it hard to start and possibly quit while driving?
Old Jun 27, 2007 | 06:24 PM
Car: 1989 GTA
Engine: 5.7
Alright i tested the fuel pressure, when i turned the key without cranking the pressure read 39-40 psi and then during cranking it went to 42-43 psi, so i suppose i can rule out the fuel pump.
Old Jun 27, 2007 | 06:31 PM
Chris`s85Z28's Avatar
Car: 1985 Z28
Engine: LG4 305 with a few modds
ohm test your injectors they should be 14.5-16.5 ohms... just a thought
Old Jun 27, 2007 | 06:32 PM
Car: 1989 GTA
Engine: 5.7
ill do that thanks
Old Jun 30, 2007 | 12:26 PM
Car: 1989 GTA
Engine: 5.7
i changed the distributor, ignition coil and still doesnt want to start up, i am getting good fuel pressure, the only thing i havent changed is the cap and rotor could that be the problem?
Old Jun 30, 2007 | 01:33 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
well what about a fuel injector issue?
Old Jun 30, 2007 | 02:43 PM
Car: 1989 GTA
Engine: 5.7
well i used a one of those test lights to check if the wires were getting power and unpluggled the wires going to the injectors and the light lit up for all of them, is there any further test i can do to test them?
Old Jun 30, 2007 | 06:23 PM
I always thought my problem was the Mass Air Flow sensor, but I never checked it.
Old Jun 30, 2007 | 09:05 PM
Car: 1989 GTA
Engine: 5.7
where is the mass air flow sensor and what does it do? is it the plug the goes into the plastic air intake??
Old Jun 30, 2007 | 10:46 PM
MedVader's Avatar
Car: 90 Formula hardtop
Engine: 5.0 TPI
I still think you have fuel problem.
Either in the fuel tank pickup being clogged or your injectors are clogged. The use of starter fluid to start the car is a key indicator. Then it sounds like the engine starves for fuel when you up the rpm.
You can have good fuel pressure if there is little flow like when starting or key on. But the obstruction shows up when you get the rpm going and need more flow.
Measure fuel pressure while you move up through the rpm to where the engine dies. I'll bet it starts dropping as rpm goes up.
Old Jul 1, 2007 | 12:56 AM
rue_69's Avatar
Just as previously stated, this is obviously a fuel problem - and also as already stated you can have good pressure without good flow. One of the things you still need to figure out is if the injector ohms are right, because you may have 1 or more dead injectors - I found 4 on my Corvette. Also, you may have some injectors that are clogged or you may even have a clogged fuel pickup.
Also, this is probably not it, but its a shot in the dark: Do you notice a pressure sound, or a sucking sound when removing you gas cap?
Old Jul 1, 2007 | 02:12 PM
Car: 1989 GTA
Engine: 5.7
I did notice a sucking from the gas tank but now its not doin it, is it supposed to do it?
Old Jul 1, 2007 | 02:14 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
I get a wierd noise when removing my gas cap just like that... what do's that entail? to much pressure in the tank from a clogged fuel system
Old Jul 25, 2007 | 01:15 PM
blackbird615's Avatar
Car: 1991 Trans-Am "Blackbird"
Engine: 305TPI LB9
Axle/Gears: Hmm
apologies for bringing back an old post but i've got the same problems.... should there be no pressure like that at your gas cap? i hear a sucking/pressure noise at the cap and when i open the cap, it releases a load of pressure inside the tank. you mean that isnt normal?
Old Aug 9, 2007 | 02:33 PM
XxGeinNothingxX's Avatar
Car: 1991 Camaro RS
Engine: 350 bored .30 over
Axle/Gears: Posi 342
Uh, ya, I would like to know this as well, mine does the same thing....realives a large amount of pressure when the cap is taken off.
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
killer777
Aug 8, 2015 02:47 PM
mustangman65_79
Aug 8, 2015 12:07 PM
