Throttle Body Sticks
Car: 1969 Chevelle SS 396
At operating temp, the throttle body sticks when I release the accelerator pedal. In the past, I've sprayed penetrating oil on the return spring and it'll be OK for a while, but will begin to stick again. When I disconnect the cable, the cable seems to move freely.
It's the original Throttle Body from the original TPI unit and has 137,000 miles on it. The bore was cleaned this summer.
Is there a more permanent fix? It will idle around 1200 RPM's till I pull on the accelerator pedal. Then the idle will return to normal.
Rick
'87 L98 IROC
Warmed over 30 over L98
K&N's, Dynomax CAT, Edelbrock Cat-back
4Wheel Disc, leather, power everything
Moon-Glow Pearl White with red "25th Anniversary
Heritage Stripes"
Rick
'87 L98 IROC
Heritage Stripes"
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Remove the air intake and spray penatrating oil all of the places where the throttle shaft passes through the throttle body.
1988 Formula 5L/5sp 3.45 gears, SLP cold air kit, MAS gutted, TPIS air foil, TPIS AFPR, MAC headers, Mac under drive pulleys, MAC cat back, Relocated MAT.
Best ET street tires 13.85
Best 60 FT street tires 1.930
Best MPH street tires 99.29
Terrell351
Jun 13, 2021 01:13 PM
mdtoren
Aug 16, 2015 05:45 PM
