Tpi messed up after clearing codes
Old Jun 30, 2007 | 04:29 PM
rue_69's Avatar
I have a 89 formula w/350 tpi,long tube headers, cai and afpr. I recently had a problem where the connection on the trans for the speedo came undone somehow and the speedo quit working, and it threw a ses light. I assumed this light was on because the ecm was not recieving any pulse from the vss. So I went ahead and reconnected the wire to the trans so the speedo would work, then I also disconnected the bat in order to clear this code - Well I waited about 30 seconds with the bat unplugged, then I reconnected it and went for a test drive. Now the car runs like complete crap! it misses all through the powerband and has almost no power - but like most tuned ports its not throwing a code, so I'm really stumped. Anyone have any ideas?
Old Jun 30, 2007 | 04:45 PM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
Re: Tpi messed up after clearing codes
Did you check all your connections and vacum lines? maybe you knocked one off when connecting the speedo back up.
Old Jul 1, 2007 | 12:52 AM
rue_69's Avatar
I wish it was that easy, but unfortunately no. Really there wasn't even anything arround that wire @ all. I am still stumped - I don't know if it has to do with the speedo being hokked back up, or that I cleared the codes.
GouldyGTR
Aug 21, 2015 10:43 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
