what kind of performance will occur from removing the EGR?
Old Oct 22, 2000 | 10:48 PM
rondubbs's Avatar
by removing this what exactly happens , and what kinds of improvements occur?
do you just block off the area where the EGR was? any chances of a code 32?
Old Nov 6, 2000 | 05:55 AM
F22Raptor's Avatar
can anyone answer this please?
'88 GTA 350
Headers, catback, free mods, Xtreme energy cam, and intake pieces
13.51@104.27, but can run better as it is.
I just put a new 2100-2300 RPM TQ Converter. I hope a 13.20 or better
RAPTOR, the baddest bird on the planet
AIM HIGH!
Old Nov 6, 2000 | 08:20 AM
blak92!'s Avatar
Getting rid of the EGR will prevent extremely hot exhaust gases from heating the manifold and cylinder heads even further. Is there performance to be gained? Not a significant gain, if none at all.
If emmissions (inspections) is not an issue then getting rid of the EGR would reduce the threat of future problems, like EGR problems, excessive carbon tracking in the manifold- which will cause idle problems ect. The less gadgets the less the problems!
If emmissions (inspections) is a concern, then keeping the EGR is worth it, since the performance gain will be minimal or non existant.
Old Nov 6, 2000 | 11:45 AM
Aaron's 87's Avatar
EGR actually cools combustion chamber temps and reduces detonation. Unhook your EGR vacuum line and see how bad it knocks. If you remove it, customize your eprom to get rid of the knock.
Old Nov 7, 2000 | 02:46 AM
F22Raptor's Avatar
I unhooked my EGR long time ago and never had any pinging
'88 GTA 350
AIM HIGH!
Old Nov 8, 2000 | 01:50 AM
BadSS's Avatar
I pretty much ditto blak92 here.
But,,, I can't stand it. I gotta say it. The combustion chambers are cooled due to the inability to "re-burn" the exhaust gasses added by the EGR. So, while the chamber temps are reduced, it's being reduced because there is air space being occupied by exhaust gasses. While the exhaust gasses are hot,, they are not as hot as compressed “clean” air and fuel igniting,, therefor reducing the chamber temps. At what cost? POWER. You may have read tech articles,, that say "you can add more timing due to the reduced chamber temps". That may be true,, but no way - repeat NONE can that produce more power than a clean intake charge with proper fuel and timing – PERIOD. Are we talking about a lot of power here? I would guess not a lot, but an improvement none the less.
I can say I have my EGR blocked off,, and while I haven't logged many miles on it yet,, I've gotten no codes. I also am experiencing no timing “problems” or spark knock (per scanner). I bought the car minus the EGR so I can’t give a before and after comparison. However, if I lived in a state where emission were checked closely I’d leave it on,, since under WOT the EGR in a sense "blocks" the exhaust gasses from circulating (if it’s working properly).
86 IROC - 9.8:1 - 355, TFS twisted wedge heads, 218/228-110, fully ported GM base and plenum, SLP runners, 52mm BBK, 24# SVO, 1 5/8" Headman headers, 3" Dyno-max, TH350, B&M Megashifter, 3.23 peg leg, 245/45ZR17s on 212 Eagles
Old Nov 8, 2000 | 05:04 AM
Omar's Avatar
Has anyone passed smog without their EGR, particularly in CA?
1989 IROC-Z 5.7L
Old Nov 8, 2000 | 09:42 AM
blak92!'s Avatar
Yes, the cobuston chambers are cooled but the actual temperature of the HEAD is increased as well as the intake manifolds heat- from the exhaust gases passing through. It is beleived GM did not drill an EGR passage in the 'vette aluminum heads because it would somewhat suppress a few horses (with the heating of the head- not the CC which is cooled to reduce NOx, more heat reduces hydros), because of the aluminums susceptibilty to draw more heat.
I beleive the egr could become a factor in the thousands of a second, for a strict racer nothing else. Again it becomes a conveniance matter (of having less gadgets) than a performance issue.
Old Nov 8, 2000 | 11:49 AM
Aaron's 87's Avatar
EGR still runs through the intake setup on the Vette. The EGR is for emissions, definately, but it can help or hurt power output. Some race cars even run EGR. When my EGR valve died, my car knocked. Maybe Camaros are different. Don't expect performance gains and be prepared for possible drivability changes.
Old Nov 8, 2000 | 03:45 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Don't forget, the computer shuts off EGR at Wide Open Throttle. It won't engage unless your road speed is High, and your idle speed is Low - and that means just cruising down the freeway, not caring about horsepower.
A spacer of sorts could probably be made to distance the EGR's hot convuluted tube from the intake, as blak92 mentioned.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 8, 2000 | 10:15 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
My car passed smog check without the EGR. IM in Florida.. The off the shelf Performance Resource chip I installed comes stock with the EGR deleted. Ive verified this with my Scanner.
Like Tom said its turned off at WOT. It only comes into play at part throttle. The PR chip I have now has more part throttle and WOT timing than the stock chip. I have to run 93 though it pings without it at moderate/heavy throttle.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Nov 9, 2000 | 09:05 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Just a quick note. The reintroduction of spent combustion gasses into the fresh combustion event is to reduce the combustion temps, not the chamber temp itself. It is to reduce NOx emissions, and usually does not adversly effect WOT power output. Just wanted to toss that out to clarify some points, hope it helped.
Old Nov 10, 2000 | 06:21 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
I thought that the EGR was disabled at WOT anyway so it shouldn't matter if you lose a few hp around town.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 160,000 miles, K&N filter
NBrehm
Aug 25, 2015 11:49 PM
novaderrik
Aug 10, 2015 12:44 PM
camaroken83
Aug 10, 2015 11:35 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
