Comments on gain using 1.6 rockers on exh of zz3 cam and edelbrock heads?
Old Nov 25, 2000 | 12:26 AM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Just curious if this is worth anything.
L98 TPI.
-ZZ3 cam with 1.6 rockers on intake, 1.52 on exhuast
-Edelbrock performer rpm heads
Would changing to 1.6 rockers on the exhuast be worth anything?
With 1.6 rockers = .544 lift
with 1.5 rockers = .510 lift
with 1.52 rockers = .5168 lift
Difference going to 1.6 is 5.3%.
According to flow numbers on Edelbrock, from 0.500 lift to 0.600 lift, there is 10 cfm (177 vs 187). Some heads have no gain or less than 5 cfm in this range, and therefore would reconise no gain with more lift. But since the edelbrock flow a bit more, the higher lift would be of assistance.
Comments anyone?
PS. Yes I have measured piston to vavle clearance and that is not a problem.
Mark.
Old Nov 25, 2000 | 03:49 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I dont think you'd gain enough to justify the cost. I used 1.65 and 1.52 roller rockers on my ZZ4 cam. The power is made on the intake side. You already have 1.6 rockers on there, so I wouldnt change it.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 25, 2000 | 10:02 AM
Mark_ZZ3's Avatar
Engine: TPI(s)
Actually I have 8 spare 1.6 rockers, so the cost is not a concern. I never had a set of heads that could handle the lift of 0.544, but now I have the edelbrocks, so it is a possibility.
I am going to be changing valve covers to something a bit flashy, so I will be "right there", hence my question about whether it was worth the time.
Mark.
Cameeeero
Sep 18, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
LT1Formula
Aug 20, 2015 09:36 PM
