Can a TBI harness be modifed for TPI??
Old Jul 10, 2007 | 11:31 AM
88TransAmFreak's Avatar
Car: 1971 Camaro
Hi All,
I have a quick question….could someone tell me if 1990 – 1992 TBI uses the exact same harness and computer as the 1990 – 1992 TPI system, aside from the fact the TPI harness has 3 extra injector plugs on each side and a different chip?
It seems like I read somewhere that on TBI if you swap out the chip and modify the injector wiring you could adapt that to the TPI system.
Correct me if I’m wrong please…..
Thanks again!
Old Jul 10, 2007 | 05:00 PM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
Re: Can a TBI harness be modifed for TPI??
The wire harness can be modified, one of the Sponcers does it, does not use the stock TBI ECM
http://tpiparts.net/inc/sdetail/1015
Old Jul 10, 2007 | 11:01 PM
walterrao's Avatar
Car: 91 RS
Engine: vortec 355 hsr
Transmission: wct5
Axle/Gears: bg3.27
im running my hsr with a tbi harness and computer, just added injector plugs, and changed tps and mat plug. you will need to make your own chip. but i have got my car to run pretty darn good like this.
Old Jul 10, 2007 | 11:20 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You most certainly can adapt a TBI harness to run a TPI engine and computer. That's the way my dad does it when he converts TBI's to TPI. I think there's a tech article on it, and if not, there has to be a ton of posts in the TPI or General forum. Its a pretty common topic.
Old Jul 11, 2007 | 03:34 AM
Kurt04's Avatar
Good to know, seems like I have a couple options now. EFI Connection will also make you a custom harness if you would like.
Old Jul 11, 2007 | 04:52 PM
Car: 1971 Camaro
Thanks everyone, I already have a custom TPI harness, chip and computer from TPI parts......having trouble getting it to run right....I was toying with the idea of cutting my losses and going to TBI or carburator since it's a little easier to mess with.
I have pics on my web-page, wish it ran as good as it looks .......
I wanted to leave my options open with whatever I decide (keep TPI, go TBI or carb)
Thanks again
Old Jul 11, 2007 | 06:03 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
I had my tbi harness converted by tpiparts.net. They did a great job and looks like a factory tpi harness.
Old Jul 11, 2007 | 06:39 PM
Sounds like you just need tunning
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Sanjay
Aug 12, 2015 03:41 PM
92purpz28
Aug 11, 2015 02:30 PM
