13's with bolt-on LB9..... possible?
Old Jul 14, 2007 | 06:24 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
anyone done it without a power adder? I'm shooting for it with stock heads & cam, what are your thoughts
Old Jul 14, 2007 | 06:57 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Re: 13's with bolt-on LB9..... possible?
nope!..not gonna happen with just bolt ons. WHen I had my 305 with all the bolt on you could throw at it....and even an LT1 cam and a 2800 stall yes then I was able to get sub 13's ...but without the stall my best was 14.1..
So the stall would have taken me about 13.7 or so.
thats just my 2cents....maybe someone has done it..but I didnt.
Old Jul 14, 2007 | 10:30 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
There is a local guy here, who now has a procharged LT1, had a 305 with bolt ons that did 13.98 (IIRC). I think he did 13.4x with nitrous.
Old Jul 14, 2007 | 10:34 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i think its very possible for a stick car, full bolt ons, the right gear and a little tuning to get the most out of the combo. do you consider 1.6 rockers a bolt on? i do and they are worth some power.
i know a guy that went high 14's bone stock with a older MAF stick 305 TPI car. Speed density cars were faster. gears tires and full bolt ons should have gotten him close
a auto 305 usually got the peanut cam, so i doubt it will get a 13 second pass. but to get close it will need every bolt on and then some weight reduction with the right converter/gear/tire. skinnies up front and light weight drag wheel would help
Old Jul 14, 2007 | 10:49 PM
MidnightBlue07's Avatar
Car: Z28 / GT
Engine: TPI 5.0 / 3V 4.6
Transmission: A4 / M5
Axle/Gears: 3:23 / 4:30
yeah more than likely you would need a nice deal of mods and bolt ons to get an LB9 in the 13s but, I never ran mine b4 so I'm wondering if my setup could possibly be in the 13s, mods in the sig.
Old Jul 15, 2007 | 12:07 AM
kairles's Avatar
Engine: 383/LGX
well I have a 90 formula only mods are K&N, edelbrock headers, magnaflow cat, 3" exhaust to a spintech muffler. LB9/auto with 2.73 posi. best E.T. of 14.7 best MPH was 93.
I have a BBK pulley set on the way, and will be ordering some 1.6 rockers and a shift kit. I may get a stall, but I plan on swapping in a T5 and I don't know if I wanna spend the $$$ on a stall that I wont have for long.
Old Jul 15, 2007 | 03:11 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Thats pretty good consdering the gears ! Mine with a 5 speed and 3.08's( 305 tpi) ran a 15.1@93 bone stock with 227'000km's on it and puffing oil. There was a guy here SLP-IROCZ I think . He ran 13's with an Lt-1 cam ...and some other bolt on stuff. SO yes it can be done pretty easilly.
Old Jul 15, 2007 | 11:48 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
judging from my mods I should be deep into the 13's.. but I am not using stock heads or cam..
Old Jul 15, 2007 | 04:57 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
heads and cam 305 TPI cars can go mid/low 13s. mine would have went mid 13s if it woulda been setup to launch. It was trapping 101 and going 13.70 with a 2.2 60ft. I still have the long block, anyone wanna buy it? LOL. All it had was stock vette 113 heads with a cam and ported stock intake. I had edelbrock headers and cat back with stock 3.23 gears.
Old Jul 15, 2007 | 08:51 PM
Andy 91GTA's Avatar
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
Ed Maher on this board used to own a 92 Z28 vert. It had a 305 auto with 3.23 gears and he managed to get it to run 14.1 @ 95 mph with a 1.8 60 ft. Here is a link to his website:
http://home1.gte.net/res0t8sj/vert.htm
There are lots of good ideas on his site.
Old Jul 15, 2007 | 09:50 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
My car went 13.85 at 100 MPH with bolt on's and the 305 5/sp. (Headers, cold air intake, 1.6 rockers, underdrive pulleys, air foil, gutted MAS)
Old Jul 15, 2007 | 11:37 PM
kairles's Avatar
Engine: 383/LGX
"- Relocated LT1 MAT"
anyone know whats so special about the LT1 MAT?
Old Jul 16, 2007 | 11:51 AM
89305formula's Avatar
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
last year my 89 305 formula went 13.90 at 99 with bolt on parts, headers,slp cold air intake, slp loudmouth, and drag radials, with a t-5 and 3.45 9 bolt rear
Old Jul 16, 2007 | 03:06 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
i luv this thread.. so many people assume a healthy lb9 wont break high 14's especially in the racing section here, a well tuned lb9 with bolt ons will give a 5.0 ford a good run, despite what everone on here says..i havent taken mine to a track yet (they closed our local strip) but im hoping for low 14's and after adding a procharger mid 12's is my goal..
Old Jul 16, 2007 | 03:26 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I have a hard time believing that the bolt on 305's are getting 99 and 100mph trap speeds.
Old Jul 16, 2007 | 04:36 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i'm struggling to hit 99 mph with my HSR L98. even tho my car is fully optioned pretty much except no t tops and no a/c anymore. i made 246 whp.
if full bolt on 305's are making that kinda of power with a stick, i can see those trap speeds for sure but that is one stout 305.
Old Jul 16, 2007 | 04:56 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
hummm...cant wait to see what I do at the track by reading this.
Old Jul 17, 2007 | 12:38 PM
Mark 89Formula's Avatar
Tim Burgess has gone high 12s with his 92 Z28 with G92 on the original 305 short block, ported stock heads, cam, complete intake, tires, weight reduction, and about every bolt-on you can imagine. He's also run high 11s on a 150 shot. The 6000 RPM clutch drops off the line and power shifting each gear help a lot. Search this board for his name; he's posted his combo and results before.
Old Jul 19, 2007 | 12:03 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
anybody else? im sure more people took an lb9 to the track.
Old Jul 21, 2007 | 09:32 AM
335_GTA's Avatar
Car: 1991 GTA trans am
Engine: 305 tpi
My best is 13.8 at 101
With bald tires and a 2.4 60 time
Old Jul 22, 2007 | 09:07 PM
1987ZTPI's Avatar
Car: 1987 IROC-Z
Engine: 310 lb9
Transmission: SEMI STOCK 700R4
Axle/Gears: 3.45 9 BOLT
**** my car is slow and my check engine light has been on with a code 36 for the past 3 years but i have lots of bolt on and i pulled a 14.68 2.00 60ft she is a slow ***** but i just did comp cams magnum roller 1.6 rockers a new 3" exhaust setup i don't think i will even hit 14.3's
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
80's Al
Mar 31, 2002 07:54 AM
zedder 1 9 9 0
May 21, 2001 04:00 PM
87kevroc
Apr 14, 2001 09:32 AM
mostafa3k
Mar 13, 2001 09:01 AM
