NO wot with supperram
Old Dec 6, 2000 | 04:15 PM
Wraith's Avatar
I put my supprram on and a 58mm bbk tb and if I push the gas all the way to the floor the thottle blades do not open all the way. Thare is nothing blocking the gas peddle. thanks
1991 Trans Am GTA, Accel 300+ ignition, underdrive pulleys, AFPR, Accel SuperRam (ported out), Edelbrock lower intake (ported out), BBK 58mm TB, TFS 23* heads, SLP 1 3/4 headers, SLP 3" cat back (no cat), CompCam .495/.502 lift, Kenny Bell strut tower brace, lower frame brace, Jeg's SFC, Lakewood trailing arms and panhard rod
Pony's can run, but bird can fly
1987 Buick Turbo-T
1977 Chevy Blazer 4X4
Old Dec 6, 2000 | 11:18 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
Is there slack in the cable w/ someone flooring the gas? Can you physically grab the tb arm and move it to WOT w/ someone else flooring it? Did you use the throttle bracket that came w/ the superram?
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N
Old Dec 7, 2000 | 06:07 AM
Wraith's Avatar
I did use the bracket that came with the super ram and I had someone open the trottle up by hand while I had the peddle floored and there was no slack in the cable.
1987 Buick Turbo-T
Old Dec 7, 2000 | 10:58 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I'm not sure that I understand whats happening, but: If you turn the side levers on the TB all the way to open and the TB plates are not horizontal, then there is a big problem with the TB itself. Find whats is preventing the TB throotle plates from laying horizontal.
If the problem is that the gas pedal can not open the plates to full horizontal, then I would suspect that the gas cable needs to be adjusted for length.
When I installed my SuperRam, I did not have this problem.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(58psi), K&N filters, Hotchkis lowering springs, Car-Pro custom chip, Lay Ind. ram air kit, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter.
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
next mod: 4.10 rear gears
Old Dec 7, 2000 | 11:07 AM
Wraith's Avatar
The problem is that the throttle cable will not open up the tb all the way. I am thinking that I might be able to make a spacer to put behind the tb. Is thare an adjustment for the throttle cable that I am not seeing?
1987 Buick Turbo-T
Old Dec 7, 2000 | 11:34 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Its very difficult to determine exactly what is causing your problem. I really got to see it.
Is the pivot for the throttle on the side of the TB in a different position as compared to the stock unit?
From the mounting face on the TB, where is the distance? And are the TB throttle levers the same length to the attachment point?
Do you have multiple places where you can attach the throttle cable to the lever?
On my car the throttle cable goes over the top of the Superram while the tranny kick down cable goes under the drivers side runner. If you have an automatic, could the kick down cable be causing some interference?
or restriction?
Hey man, I realize that I may be asking a bunch of stupid questions. I wish that I could actually check it out with you.
Old Dec 7, 2000 | 11:48 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Wraith,
You told me once before where Bradford is. Please remind me again.
Doc
Old Dec 7, 2000 | 05:41 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Often the sound insolation and stuff are under the pedal and prevent full travel.
Pull the carpetiing down and trim the stuff to that the pedal has only the carpetiing between it and the floorboard.
It that doesn't do it then split a few 10-32 nuts with a hacksaw, and install them between the end of the cable, and the pedal to take the slack out.
Old Dec 7, 2000 | 10:00 PM
Wraith's Avatar
There is nothing blocking the gas pedal from going all the way down. As for the distances between the bracket and the throttle lever on the tb I'm going to check that out tommarow. doc, bradford is about 15-20min west of piqua on state route 185.
1987 Buick Turbo-T
Old Dec 8, 2000 | 11:37 AM
Bjorn's Avatar
Car: 86-IROC Z28
Engine: 327
Transmission: 700 R4
If there is too little leverage on the gas pedal and there is nothing preventing it from flooring properly a way of getting more leverage is to modify the upper stop for the pedal. It takes a little careful bending of the bracket that holds the gas pedal. That way you can achieve a little more travel for the cable.
Hope this helps.
Old Dec 8, 2000 | 10:07 PM
irocz's Avatar
Car: '87 IROC-Z
Just to clarify this for me, when someone is flooring the pedal the TB blades aren't horizontal? While they're still holding the pedal, can you move the tb arm yourself to move the blades to WOT or is there some obstruction? Are you sure you don't have the cruise control and throttle cables mixed up?
It's been a few months since I saw my TB so it's a little vague still.
Old Dec 9, 2000 | 06:25 AM
Wraith's Avatar
irocz, with the peddle floored someone can open the throttle blades the rest of the way by hand (there is NO restriction). I know I put the cables on right on the tb (they only go on one way). I'll look and see about the gas peddle to see if I need to bend anything. Thanks
1987 Buick Turbo-T
Old Dec 9, 2000 | 04:20 PM
Omar's Avatar
i am currently having the same problem. If you look at your pedal assembly, you will see that Grumpy's solution is the best one. The cable itself is supposed to be non-adjustable.
1989 IROC-Z 5.7L
Old Dec 9, 2000 | 05:19 PM
Wraith's Avatar
I'll have to check that out when I get time and when there is no snow on the ground. Thanks everyone.
1987 Buick Turbo-T
Old Dec 9, 2000 | 06:07 PM
Omar's Avatar
Wraith, I just fixed mine. I did it by adding, in my case, 3 10-24 nuts onto the linkage. Disconnect the cable at the throttle body. Go inside the car, and gently pull the cable a little towards the rear of the car, giving you some slack. Now you install some nuts onto it. The tricky part is that you have to hacksaw a slit on the nut in order to slip it on. But that slit has to be JUST enough for the cable to pass through it with some pressure, but not big enough that the nut will fall right off with ease. How many nuts you use will be a trial and error for you. Now re-connect the cable at the throttle body, and test it out. Since you have taken up the slack, check to see that the throttle body is actually closing all the way. If it isnt, you need to go back to the pedal. If you look at the bracket, you will see how the pedal comes to rest against it. It's an arm that you need to simply bend back a little. It might sound confusing, but when you get see it all, it is easy. If you find something better than nuts to use, let me know.
1989 IROC-Z 5.7L
Old Dec 9, 2000 | 06:28 PM
Wraith's Avatar
Thanks i'll look into that.
1987 Buick Turbo-T
junior419
Apr 7, 2025 11:35 AM
Pac J
May 17, 2020 10:44 AM
86White_T/A305
Mar 6, 2016 01:48 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Damon
Sep 26, 2015 04:29 PM
