Rough Idling and Surging
Old Jul 30, 2007 | 08:19 PM
guitargod's Avatar
I've been have much trouble with this for a long time now. When first cranked up the car idles real rough jumping from 500 to 1000 rpms , after warming up the car then starts to surge and the engine light flashes on and off as it does it. Sometimes when stoppingthe car also stalls. Here is a list of some parts i replaced:
Replace most vacuum lines
Fuel Sending Unit and Pump
Fuel Filter
IAC Valve
Purge Canister
PCV Valves
TPS
Coil Pack
Plugs and Wires
O2 Sensor
After looking around I've read it may be my injectors..any ideas??
Old Jul 30, 2007 | 08:36 PM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
Re: Rough Idling and Surging
What car, motor, year ?
Do you have any trouble codes set? -- http://sethirdgen.org/dtc.htm
Your problem sounds a lot like a problem my friend had with his 89 GTA.. He had a bad MAF sensor.
When you start the car and it's running bad, unplug the MAF.. If it starts running better, then that's a sign the MAF could be bad.
Old Jul 30, 2007 | 09:07 PM
guitargod's Avatar
its an 89 Formula 350 and no codes are set
Old Jul 31, 2007 | 12:28 AM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
is the TPS set right? .54v
Old Jul 31, 2007 | 06:38 AM
guitargod's Avatar
yes
Old Aug 2, 2007 | 12:22 AM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
had the same problem i put my old tbi iac and it fixxed the problem
it will just idle 100 rpms higher but no more surgeing or stalling
in park it idles around 850 but 600 in gear
Old Aug 2, 2007 | 02:50 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Holley AFPR?
Old Aug 2, 2007 | 09:42 AM
guitargod's Avatar
are you asking if i have that installed or if i should get it? b/c currently no i have stock pressure regulator
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
89fast5oh
Sep 8, 2015 09:55 AM
IROCtometal
Sep 2, 2015 02:01 PM
