MAF and MAP power, same engine
Old Jan 10, 2001 | 05:25 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Which system will make the most power, MAF or Speed Density when used on the exact same engine?
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Jan 10, 2001 | 10:22 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
They both have their advantages and disadvantages. Do a search on the PROM Board on "MAF" and then "MAP"; that you should bring out a lot of points about both.
Old Jan 10, 2001 | 06:31 PM
Engine: 4.0L
I checked the archives but could not find anyone that has done a MAF vs MAP dyno/timeslip on the same engine.
86 Camaro Sport
My Camaro Project
Old Jan 10, 2001 | 06:55 PM
Car: Death Mobile
Engine: 666 c.i.
I doubt you are going to find a post where someone timed there car with MAF and then converted to MAP and re-timed it.
People generally convert from MAF to MAP for a variety of personal reasons...(I've never seen anyone convert from MAP to MAF though the newer 4th gen version may be interesting).
There was a recent discussion (I believe that it was on the TPI Board discussing the advantages of both)...find that post.
Old Jan 10, 2001 | 09:08 PM
Guest
Guest
Posts: n/a
Actually, go find Mike Davis' site, he did just that. If I remember right, it was basically a wash, but I think someone told me he ended up finding some more power out of the MAP system. If there is any difference, its minimal. I would just say its the same but the MAP is easier to mess with simply because nobody pays any attention to the MAF setup.
Check the prom board to try and track down where Mike Davis' site is.
[This message has been edited by madmax (edited January 10, 2001).]
Old Jan 11, 2001 | 05:34 AM
Engine: 4.0L
Thanks, I'll try that site.
Maybe I should get hard numbers before and after the swap because I am doing it soon. I have too many MAF codes once in a while that I know are just glitchs. Also I want the "passkey" and thay are easier to scan then a MAF system. I am going to start burning my own PROMS too.
86 Camaro Sport
My Camaro Project
Old Jan 11, 2001 | 10:11 AM
Car: Death Mobile
Engine: 666 c.i.
Those are good personal reasons. I also think there is more help available on the PROM board for the SD guys. Probably because more of the SD guys burn their own eprom.
Old Jan 11, 2001 | 12:17 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
Mike Davis' site is: http://www.ece.udel.edu/~davis/z28/
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Old Jan 11, 2001 | 01:21 PM
Guest
Guest
Posts: n/a
I am working on a fix for the code 33 problem, but no guarantees as of yet I havent burned a chip to check it out and see if I did find the offending section of the bin file. The 89 ARAP code would then be comparable to what you are looking for I think, but if this is something you are going to do right away, by all means ditch the MAF.
89GTAOz
May 16, 2020 09:31 AM
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
