AFTER MY CAR WARMS UP IT FEELS DIFFRENT
Car: CAMARO IROC-Z
Engine: 350 T.P.I
WELL THE FIRST TIME STARTING IT UP AND FLOOR IT IT WILL BURN RUBBER BUT ONCE THE THE TEMP HAS RAISE IT FEELS SLOWER AND DOES NOT HAVE THAT GOOD OF ACCELARATION DOES ANYONE KNOW WHAT MIGHT BE THE PROBLEM OR IS THAT NORMAL IT IS 1989 CAMARO IROC-Z 350 TPI POSI 700R4 TRANNY AUTOMATIC
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
Re: AFTER MY CAR WARMS UP IT FEELS DIFFRENT
plus either a 180 or 160 degree thermostsate and a jet fan switch helps too, it puts the fans on alot sooner than stock.. flush youre radiator lately??? fresh coolant and water always helps keep temps down. that new purple ice additive seems cool, maybe ill give it a shot. all cars slow down ounce hot.. stop and go sucks in these cars.. too much heat.. Thread Starter
Car: CAMARO IROC-Z
Engine: 350 T.P.I
thanks i will do that i had a question buging my mind i heard to diffrent answers will the engine get damaged if you run the cooling system with 100% coolant no water
Car: 1989 T/A
its summer u need water... guys used to run all water very little coolant and no stat at all in the summer... i never heard all coolant???maybe in winter months.. do a 50/50 and if u need to add ,just add water..best bet.. plus u need coolant so things like youre radiator and waterpump dont crap out on you.
Car: CAMARO IROC-Z
Engine: 350 T.P.I
yeah because right now im running it about 50/50 i was thinking of adding that additive that claims it keeps your engine cooler you think its any good and also i am not running a thermostat
A cold air intake and a TB bypass will help alot with that.
Car: 1989 T/A
should be.. royal purple products always work as advertised (usually) its worth a try.. i probably pick some up next time i go to the speed shop.
Car: CAMARO IROC-Z
Engine: 350 T.P.I
i think im going to go ahead and give it a try too so the tb bypass helps alot to
Car: 1989 T/A
I did the tb bypass and only noticed a slight increase in throttle responce and the car ran a little better. But im in the desert, :shrug: it gets hot here anyway. But it sure couldnt hurt, unless you live in the fridged north and need it to heat the car on cold starts.
so why does slp make that cai? in that case every car has cold air, because most filters are routed near incoming air.
At the end of the day there's no magic that happens inside that hunk of plastic. If the airflow is NOT coming from under the hood, which nowadays most EFI cars are not, then technically they're already "cold air". But none the less, gimmics make money. Now I'm not saying that some aftermarket "cold air" intakes don't FLOW better than stock, but it's typically not air temp that's causing you to see a gain.
maroe624
Apr 16, 2017 08:29 AM
