Fuel injectors in a 91 305 TPI
Old Aug 11, 2007 | 09:21 AM
91FirebirdFmla's Avatar
Car: Green 1991 Firebird Formula
See my post in the Tech/general engine forum for detailed background:
https://www.thirdgen.org/forums/tech...-not-fuel.html
But my problem has definitely moved into the TPI realm.
I was running incredibly rich and narrowed it down to bad fuel injectors. I sent them to get cleaned. They were very rusy inside, 2 were bad and had to be replaced due to low resistance. They ohmed fine when I tested them 1 year ago but thats another story.
I asked the technician what pound rating my injectors were and was told 21#. I was under the impression that all 305's had 19# injectors. That is the impression I get from my search of the boards as well, except for this post where according to CruzinPerformance, a car of the same year and drivetrain as mine should have the 22#:
https://www.thirdgen.org/forums/tpi/...ize-305-a.html
I'm farily certain my injectors are original if anybody could confirm that some 305's came with the 21/22# injectors, it would make me feel better about reinstalling them. Installing injectors that are too big isn't exactly going to help my problem with running rich.
Old Aug 12, 2007 | 08:10 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Fuel injectors in a 91 305 TPI
I've never heard of a 3rd gen 305 running anything larger than 19# from the factory.
Old Aug 12, 2007 | 08:47 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
I have an 87 IROC 305 that had the stock injectors when I bought it. A part number search on the internet showed them as being 20.6 lb/hr as I recall. I have also moved into the PROM programing world, and can state for sure that the stock PROM injector constant is 20.82 for my car. I know that most everyone on this board thinks that 305's all had 19 lb/hr injectors, but it seems that in 1987 they were closer to 21....
Old Aug 12, 2007 | 10:34 PM
That is good to hear. I am unfortunately not yet at the level where I can check my injector constant and eliminate all doubt. Although I found out that when I was told what my injector ratings were, it was not through a specification in a catalog. The 21lb flowrate was based on a simulated injector test at 80% duty cycle and 6500 RPM. I an unsure as to whether this is a standard way of measuring injectors. In any case, because of the confusion, Accurate Injectors is going to pull a stock fuel injector for my car off their shelves and compare it to what i sent them. Then I will know for sure what came stock in my car. I'll be sure to update this post accordingly.
Old Aug 16, 2007 | 10:26 AM
88blackgta's Avatar
Car: 88 GTA Notchback
Engine: 355
All 305's came with 19 lb/hr injectors. If you re-read the thread that was referred to, Five-0-motorsports were the ones that said 22 lb/hr were correct for the 305 not Rich @ Cruzin. Rich only stated that the Multecs weren't worth cleaning/flow testing.
Brcharrelson
Aug 26, 2015 07:47 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
kyleb24
Aug 15, 2015 08:24 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
