You guys look at the Lingenfelter setup and tell me what you think it would get....
Old Jan 10, 2001 | 09:28 PM
Monkie's Avatar
Ok if you started out with a stock 350 TPI and did the following mods how much HP would you about have and what do you think you would run on the 1/4 mile?
LPE SuperRam plenum runner kit
LPE SuperRam base intake manifold
LPE high flow TPI runners
LPE 52mm TB
LPE SBC EFI Camshaft
LPE high performance valve lifters
Comp Cams Hi-Tech stainless roller rocker arms
Comp Cams valve springs
Free RAM AIR thats in the tech section
March underdrive pulleys
Bigger fuel injectors
LPE modified mass airflow sensor
SLP headers
High flow cat
and finally a Borla catback
Thanks guys!
Old Jan 10, 2001 | 10:28 PM
Yarnboy's Avatar
What year? I'd say that that's good for 160 hp..I may get yelled at for being 156 hp off so I am not sure. Don't get the modified MAF..save your money and buy cool stickers to show all the parts you bought
-Red '88 IROC 5 Speed 305 TPI w/3.08
-Dual Friction Centerforce Clutch
-Accel 300+ Racing Ignition
-Accel 300+ Pro Sleeve Plug Wires
-Accel U-Groove Plugs
-Flowmaster Force II 3 Chamber Cat Back Exhaust
-Hypertech Chip
-Hypertech Airfoil
-Removed, Then Re-installed (out of fear) MAF Screens
-Gutted Air Box
-Best E/T 14.686, 60' 2.205, 1/8th mile 9.461, 1/4 MPH 93.91
-Best 60' 2.17
Old Jan 11, 2001 | 07:07 AM
Monkie's Avatar
Prolly like a 89 IROC engine.
Old Jan 11, 2001 | 09:51 AM
blak92!'s Avatar
What about the heads? That would be my first mod. BTW, I might sell a set of brand new AFR 190s 58cc chambers this weekend.
'92 Z28 Black 5.7L 5 Speed
'95 Competition Yellow Corvette Coupe 6 Speed
Old Jan 12, 2001 | 10:19 AM
GlennS87's Avatar
I'm basically doing just that. I've gone to a 4 bolt block, eagle cast crank, 6" forged rods and piston to get about 11.1 compression. By substituting certain parts, (such as comp cams pro magnum 1.6rr's instead of hit tech rollers, and a local builder putting it together) I'm hoping to get close to what Lingenfelter gets out there L98 combos- about 440hp.
Neptune, NJ
White '87 Vette- modified maf, TPIS big mouth manifold, SLP siamesed runners, no pre-cats,hi-flo main cat, Walker Ultra flows and y-pipe w/crossover,ported plenum,adj. fuel pressure reg.,cut out air filter cover,
auto(trans kit,shift kit), 2300 stall converter, k&N filter, 3.07 rear diff., Silver ZR-1 wheels 17x9 and 17X11
Old Jan 12, 2001 | 04:44 PM
calroc's Avatar
Glenn,
Lingenfelter gets that 440HP from a 383c.i., and A LOT of port work to those alum. L-98 heads.
85 calif. iroc
383/A4
9" rear
Old Jan 17, 2001 | 09:58 AM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
First of all, you NEED heads to make that setup effective. Good heads w/ an intake and cam to back it up will make the hp. As far as 160 hp, I think you should keep dreaming. And BTW, you don't need high flow runners. The ones that come w/ the Superam plenum must be used. The 219, AFR's and Superam would be rel nice, but it's expensive.
Justin 87 GTA--organizer: "NY2K" Gathering. Blk/Gld w/Superam, 355cid Trickflows, forged pistons 9.5:1. Auto 2,600 stall, 3.45 9 bolt disc, Best time & mph 13.567 @ 101.900 w/ a poor 60ft. Best mph: 104.3 *This car is 100% NYS emissions legal, w/ all emissions controls!* "If you want to have a fast car, hang out w/ those who do!"
http:// www.community.webtv.net/munks87/JustinsGTApage.com
Old Jan 22, 2001 | 12:45 PM
GlennS87's Avatar
Calroc,
You're right, I guess I didn't read the first post carefully enough. I'm essentially mimicking the LPE 383 package and saving here and there are certain parts, My heads are being completely reworked with valves the same size that LPE uses. They are also being ported. I have the aluminum heads since this is a Vette, but they are not D-ports like LPE uses. The motor is being built locally by someone who buils race engines for local racetracks.
Neptune, NJ
White '87 Vette- superrammed 383 in process
Old Jan 22, 2001 | 01:14 PM
Kyle F's Avatar
Monkie, no offence, but why did you ask this question.
The last I checked you had a 92 Maro V6 an were plannnig on Building a Turbo 6.
With that I would say without heads or cam your not going to see much at all, like maybe 50hp. Now you put a set of heads that can use the extra air flow, and a cam that will use the new RPM range of power provided with that setup and on a good 350 you looking at a possible 450hp depending on heads and cam selected. If on a 383, again depending on Heads/Cam you could get to around 550HP. These super ram set ups are made to flow huge amounts of Air to feed big/heavily modifid engines. I saw a Supercharged Formula 350 with that set up and a Vortech blower on it, not sure what heads or cam was in it, at Cars 2 NV here in Columbus and it had a dyno sheet of like 746 Rear wheel HP. It was featured in some magazine and had an issue of it in the car. It was forsale for $20,000. And worht every penny to
Old Jan 22, 2001 | 02:22 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Maybe Monkie's considering other alternatives to a V6 turbo? That's fair and a smart thing to do. I think its wise to analyze ALL the costs for various swaps and determine what is the most cost effective (and easiest) to do.
Also, Monkie's state may have squashed his V6 turbo swap as "illegal" because of the year.
Monkie, if you are considering a swap to a V8, going carb will be the cheapest if you can legally do it. If not, consider going with SD over MAF as it is simpler to do. You can even reuse your ecm as it is the same for an SD TPI car; just need to get a SD TPI wiring harness or modify your existing one. Then, all you have to do is learn to burn your own eprom (plenty of us SD guys on the PROM board) and you are set.
As for the Superram, it doesn't have the nickname SuperPITA for no reason. It can be a bitch to install. And, frankly, it still is inferior to the MiniRam IMO.
Gotta love a one piece unit thats a snap to bolt on.
Old Jan 23, 2001 | 06:47 AM
Kyle F's Avatar
Why would a Turbo 6 swap be illegal? It would be as clean as a Carbed V8 of anykind.
Old Jan 23, 2001 | 07:41 AM
blak92!'s Avatar
Because a turbo V6 was not an available option for the vehicle. A TPI in a monte carlo is illegal even though TPI is more efficient. The EPA exist to protect the interest of major corporations that pollute. The major corpaorations have and generate too much money to have restrictions put on them, so who does the EPA go after? Us, the common people. Cars now produce such minimal amounts of pollution that they do not have a significant impact on the environment, unless the vehicle spills its fluids and upsets the eco system.
Old Jan 23, 2001 | 08:34 PM
Kyle F's Avatar
Test are done on emissions passin out the exhaust by the year, make and model of you car. So all monkie has to do is say he put a Turbo on his 3.1. The turd running the tester isn't going to know the difference between a 3.1 and a 3.8 block. Hell I dont even know if I would know. Monkie if you can find a parts car the Turbo 6 is a much better, and cheaper, option.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
Street Lethal
Aug 14, 2015 08:25 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
