Question about Worlds Product Sportsman Heads
Old Jan 25, 2001 | 11:19 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Has anyone ever used the Worlds Product Sportsman-II Heads with a TPI setup!?? They have a 200cc runner and I'm wondering if there is any match-up problem with the heads and a stock TPI intake like there is with the AFR heads and the edlebrock intake!!?? I'd really like to buy these heads but I don't want to spend nearly $800 on the heads and then find out they won't match up to the intake!!
1986 Trans AM
305 TPI
4 Wheel Discs
9 bolt Borg Warner Rear
Completely Stock
Soon to upgrade to a 383 stroker w/TPI, Hedman Shorty Headers, 64cc Pocket Ported Worlds Product Sportsman-II heads, ported intake, comp cam, TPI air foil, Adjustable Fuel Pressure Regulator, possibly bigger injectors!
Current project: Keeping my car running until I get the money for the above mentioned project! :-)
Old Mar 21, 2005 | 10:52 AM
Dustin89GTA's Avatar
Car: 1989 GTA
Engine: 355 TPI
Transmission: 700R4 (w/ shift kit)
Axle/Gears: 3.27 (stock)
I'm running a set on my 355 with stock TPI setup. They seem to flow pretty well, however they needed to be resurfaced, and they didn't drill the valve cover bolt holes deep enough.
I'm not sure if anyone else has had problems with them.
Old Mar 21, 2005 | 12:07 PM
firebirdjones's Avatar
World heads
I use a pair on my monza with a 406, although I have a carb setup on that. Can't say for sure there would be any TPI related problems, but I can tell you I have had no problems with them otherwise, decent head for the money. Larry.
Old Mar 21, 2005 | 12:20 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I'm using them on a 383 in my 91 Firebird with a SuperRam intake. No problems at all. Mine are ported a bit to improve the flow, but that shouldn't matter in relation to your question.
Be advised that the EGR provision is not "automatic" on these heads. It needs to be drilled it you want to use EGR.
I didn't have any problem with the valve cover bolts either. I'm using perimeter valve covers and put threaded studs into the heads and use the long T type hold downs on mine. Here'a a pic that probably explains it better:
Attached Thumbnails Question about Worlds Product Sportsman Heads-c-documents-settings-c1328
Old Mar 21, 2005 | 10:07 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
No mounting problems on mine. I drilled the egr (just need a 1/4" drill longer than 6" to get in there but it was easy)
If you plan to use centerbolt valve covers, you'll need to cut down the bosses a little bit that are there for the perimiter style covers.
I'm using perimiters because I forgot to do it until I already had them bolted in (was just too anxious!)
You'll need to re-angle the center 4 bolt holes if using a "newer" base manifold but that is quick to do.
Had it running in the garage for hours with no leaks and everything went to gether nice.
Haven't gotten out on the road with it yet, but it sounds promising.
Edit: mine was a stock 87' setup
Old Mar 21, 2005 | 10:22 PM
vernw's Avatar
Say JP86SS - what is the procedure for drilling these for EGR? My engine builder didn't drill mine, and I'm considering doing it. Is it possible to do with the heads still installed, or do they have to be pulled? I'm wondering if it's something I can do with them still on the motor....
Old Mar 21, 2005 | 10:32 PM
JP86SS's Avatar
I wouldn't really suggest doing it on the motor although by pulling the intake to gain acces to the ports, you just drill at an angle though bout 1/8" wall into the exhaust port behing the valve.
Not hard, just need to get one of those long 10" drill bits 1/4" diameter.
The chips will "most likely" get blown out but I cringe to think what would happen to that pretty motor if the EGR popped open before it was all cleaned out.
Old Mar 21, 2005 | 10:37 PM
vernw's Avatar
I'm still not quite sure where to drill the holes, sorry for being so dense. I've got an EGR valve on my LPE intake, it's just not doing anything. May have to talk to WP to get more details....
So you don't think a shop vac would pull the chips out, huh? You're probably right. I'll probably just leave it EGR-less for now.....
Old Mar 22, 2005 | 06:03 AM
nitrovette's Avatar
Car: 73 corvette
Engine: 2004 ls1
i run them on my 360 ,still plenty of lowend torque.and both style valve covers fit with no mods at all for me.
Old Mar 22, 2005 | 05:28 PM
JP86SS's Avatar
The chips would mostly stay in the top on the intake side until you break through.
But when breaking through they would land on the back side of the exhaust valve.
I'd be afraid of first cranking when the valve opens and drops in a small piece
Maybe next winter (after some summer fun) project.
Nitrovette, I still love those blue runners!
I broke down and polished mine although I don't think I'll keep them looking nice and will probably do the transparent red over them eventually.
Old Mar 22, 2005 | 07:42 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Interesting thread. The first poster could not get an answer for four years. But 4 years later his post comes alive. Allen
Old Mar 22, 2005 | 08:29 PM
JP86SS's Avatar
No Sh%t !
That's a good one. Vern needed some info so there was some good to come from it!
Old Mar 22, 2005 | 08:30 PM
JP86SS's Avatar
I guess that means they work ok
Old Mar 24, 2005 | 04:18 PM
vernw's Avatar
Sure do --- and I appreciate all the info I got!!!!!
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
