miniram or edelbrockbase&slp siameeze runners?
Old Jan 26, 2001 | 09:26 PM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
my project motor is a 383stroker ,sportmans II heads, 1 5/8 headers 3.73 posi 700r4 tranny. i want my power from idle to 5500 rpm no more than that. daily driver. which one would b best? also what size injectors do u recomend 22lbs or 30lbs?? thank for your reply.......
Old Jan 26, 2001 | 09:46 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Miniram...without a doubt.
Old Jan 27, 2001 | 12:16 PM
mirage2991's Avatar
hummm its a tough one...Minirams are great, but I think they are really ment to turn above 5500. More like 6500. I think for a daily driver, the aftermarket long tube and edelbrock base should get you where you want. I think you would make great torque/hp from 2000 to 5500. Midrange for a daily driver is what you want. And then there the questions of cubes too...I like my slp/edelbrock combo...my only regret is not to have changed the cam...
85 Z28, 355, edelbrock base, SLP runners (old style) 58mmTB, ported plenum, stock cam, fuel reg, TES headers, flowmaster, 3.73's, shift kit, MSD 6a, 305 hypertech chip (YUUUCK!) best prior intake mods: 14.6 @ 94, 2.02 60' temp: 78deg, 80% moist, on radials.
69SS, black, 3,73's, TH400, 402 BB, roller everything (solid 246@50 622 lift)+stud-guirdle, 67 Vette heads ported and o-ringed, about 10:1 cr KB pistons, should be done this summer, goals: 500hp and lots of fun
Old Jan 27, 2001 | 01:09 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
For idle to 5500 RPM I think your best choice would be the Eld base and SLP runners. The Mini ram makes lots of power, but it makes the power at higher RPM (6500) then the Eld base and SLP runners.
1988 Formula 5L/5sp 3.45 gears, SLP cold air kit, MAS gutted, TPIS air foil, TPIS AFPR, MAC headers, Mac under drive pulleys, MAC cat back, Relocated MAT.
Best ET street tires 13.85
Best 60 FT street tires 1.930
Best MPH street tires 99.29
Old Jan 27, 2001 | 07:58 PM
Killer-Z's Avatar
Yes but are slp or the asm runners better
Old Jan 27, 2001 | 09:19 PM
88 IROC BOB's Avatar
Everyone says AS&M. That's what I'm going to get!
Bob
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Old Jan 27, 2001 | 11:53 PM
Mo's Avatar
Mo
There was a nice post awhile back showing how AS&M were better, they looked pretty good to me, if I ever get around to that point wiht my car, I think I'd get those
Old Jan 28, 2001 | 01:11 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Edelbrock base and AS&M Siamesed runners.
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Old Jan 30, 2001 | 11:55 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I'd say that I agree with IROC Bob, Mo, and 88GTA to recommend the Edelbrock base and the AS&M's if you favor performance without regard to cost.
However, I still think that at less than $250, the SLP runners are a great bargain, once you clean up the openings and modify your plenum to match. What's the going rate of a set of AS&M runners these days, anyway? $450??
Old Jan 30, 2001 | 12:09 PM
JAY87GTA's Avatar
They had an article in Car Craft magazine about a year and a half ago where they put a pair of the Accell LTR's on a Formula. They ran it back to back and picked up .3 sec. Somebody with more experience can tell you if the AS&M runners are even better, but that's proven. Let me dig around some and see if I can find the article and give more specifics. Later
'87GTA w/ SLP Cold Air, MSD Coil, Airfoil, Gutted MAF, AFPR, TES Headers, HI-FLOW CAT, Flowmaster Catback, Energy Suspension Master Bushing Kit
Old Jan 30, 2001 | 01:02 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
That was Tom Keliher's car.
Old Jan 30, 2001 | 02:25 PM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
Everybody says AS&M runners are great. So where can I see them? who is AS&M? Do they have a web site?
Sounds like I'll be saving up for an Edelbrock base and a set of those AS&M runners...
89 Firebird Formula
WS6 package,ZZ4 Crate engine
SLP 58MM TB, Edelbrock TES Headers
Random Tech 3" cat, SLP 3" stainless exhaust
9 bolt rear, Hotchiss swing arms, Lakewood panhard rod
Corvette 2/4 servo, kevlar band, full poly rear.
Centerline 16x8 rims, B.F Goodrich drag radials
Old Jan 30, 2001 | 03:45 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Lol, i remember that. We had the thirdgen exclusive...lol
...ed
Old Jan 31, 2001 | 02:04 AM
Dan87IROC-Z's Avatar
Miniram for sure, its by far better than any other TPI type intake on the market!!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Jan 31, 2001 | 01:37 PM
Kevin91Z's Avatar
AS&M is at http://www.azspeed-marine.com/
Old Feb 1, 2001 | 02:43 AM
88IROCs's Avatar
I'd say for the price of Edelbrock/ASM combo you could buy a MiniRam: both would cost around $800. But don't forget, for either one you'll need to buy a lot of supporting parts: larger TB, new cam and valvetrain, better exhaust, better heads, etc.,... Otherwise why bother?
There's a lot of rumours that the MiniRam works great at the top only. However, I've yet to see the proof(i.e., a dyno sheet) to back that up, and the guys on this board who run a MiniRam will be only to happy to squelch those rumours.
Now if you don't want to do extensive mods, I'd say get the Edelbrock(or TPIS) manifold and match it with either Edelbrock, SLP or TPIS runners.
Old Feb 1, 2001 | 03:12 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
So....
Why not use an Accel Super Ram?
It was designed for 383 CID and larger small blocks making power between idle and 5800 RPM.
Or....
While the AS&M runners are better flowing than "off the shelf" SLP runners, The AS&M are welded tubular aluminum and the SLP are cast aluminum. The AS&M don't have very thick walls and can't effectively be ported. Basically, what you get when you buy the AS&Ms is what you have from then on unless you cut them open, modify, and then weld them back up.
Since the SLPs are cast in an oval siamesed configuration with lots of material, you can port the living daylights out of them.
The SLPs aren't excactly great flowing out of the box but have tremendous potential. The inside port diameter can be enlarged considerably and the septum dividing the adjacent prts can be removed in whole or in part to "customize" individual port length. By doing this you can easily create a runner tuned to your airflow/RPM requirements.
22 lbs/hr injectors should be just fine as long as they are clean and working correctly.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
My IROC-Z
EFI Performance Club on Yahoo
Club IROC-Z
[This message has been edited by IROCKZ4me (edited February 01, 2001).]
Old Feb 2, 2001 | 12:04 AM
tastedapain's Avatar
HEY DUDE...IVE DONE YOUR COMBO ALREADY....FIRST OFF....UP YOUR HEADER SIZE TO 1 3/4 THEN CHECK OUT MY AD IN THIS SECTION FOR MY MINI RAM AND EDELBROCK LARGETUBE SYSTEM FOR SALE.....BOTH EQUIPPED WITH POWER NUMBERS....BEEN DOING WORK WITH TPI'S SINCE 1985.....LET ME KNOW IF U GOT ANY QUESTIONS...BOTH SYSTEMS ARE PRICED TO SELL!!!CHECK EM OUT
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Chas91Z28
Oct 22, 2015 10:12 AM
Royal_Z
Sep 30, 2015 08:45 PM
