I need your opinion on the intake and heads being ported
Old Feb 11, 2001 | 01:37 AM
oldblueZ's Avatar
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
Next week I am going to have new injectors and an AFPR put in. It's a 305 TPI. At the same time, I am having the shop port my plenum.
They asked me if I wanted my heads ported too. I was wondering if porting my heads would be worth it. I don't think that it would cost tooo much more to have the heads ported, but I don't know for sure.
Should I also have the base and the runners ported?
My income level really sucks too because I am in college. It's only a 305 and I am not looking for a super fast engine right now. I just want something with a little more zip than what I have right now.
Basically I am wondering if porting the base and the heads would be worth the money.
I would do the work myself, but I have absolutely NO access to tools, which is really getting on my nerves.
Thanks,
Jesse
85 Z28, 305 TPI A4
pretty stock with MSD and a few other toys
15.2@91mph
http://photos.yahoo.com/j_hougnon
Old Feb 11, 2001 | 01:51 AM
Guest
Guest
Posts: n/a
Sounds like you are on a limited budget. Its gonna cost a bunch more for them to go to the extent of pulling the intake and heads to port them. How much they getting you for on the plenum and injector swap?
It would probably be cheaper to look into some 1.6 ratio rocker arms, just the stamped steel ones, to pick up a few more hp.
Old Feb 11, 2001 | 08:57 AM
oldblueZ's Avatar
Car: 85 Z28
madmax, I should be getting a rough estimate sometime soon. I gave them the list of everything to be done. I already have all of the parts, all they have to do is put them on. I would do it all myself, but I can't get to any tools.
Who makes stamped steel rocker arms, the only ones that I have seen are the crane cames gold ones.
Thanks,
Jesse
Old Feb 11, 2001 | 11:30 AM
robert1's Avatar
I put a 305 setup on a 350. The only thing I did was hand port the plenum. These engines live on torgue, which means air velocity. The passages are fine for a 305.
I would DEFINITELY get the injectors cleaned, and matched. This is critical to fuel flow. It will cost $100, but the best thing you can do.
Old Feb 11, 2001 | 11:32 AM
robert1's Avatar
I forgot one last thing. Modify the air box, yourself, and maybe get an airfoil for $60.
Old Feb 11, 2001 | 11:57 AM
Guest
Guest
Posts: n/a
Crane makes stamped 1.6 rockers. PN 11802-16
Summit has them for $80, may be able to find it cheaper.
Old Feb 11, 2001 | 12:05 PM
oldblueZ's Avatar
Car: 85 Z28
Thanks for the part number Madmax.
One more quetion, are you saying to have the heads ported and add the 1.6 rockers, or just stick on the 1.6 rockers and not port the heads.
From what I have gathered from both boards, it sounds like I don't need to have the base ported.
Oh, I already have an airfoil, I picked one up from SLP back when they were $40 last year.
Thanks,
Jesse
Old Feb 11, 2001 | 12:17 PM
Guest
Guest
Posts: n/a
I think when you find out how much they will want to port the heads, youll change your mind...
Id put the 1.6's on without doing the heads.
Old Feb 11, 2001 | 12:43 PM
oldblueZ's Avatar
Car: 85 Z28
If I want to get rid of the blue smoke at start up, that means that it has something to do with the valve seals right? So if I have the heads ported, then I will have to get new seals. I could also get the 1.6 rockers.
From what I saw that they ported on another guys heads, they just did the area behind the valves.
Thanks,
Jesse
Old Feb 12, 2001 | 03:25 PM
oldblueZ's Avatar
Car: 85 Z28
TTT
Old Feb 12, 2001 | 03:32 PM
Guest
Guest
Posts: n/a
Dont have to remove the heads to replace the valve seals. You do have to move the rockers though, so it would be a good time to change them. New springs arent a bad idea either, stock ones IMO suck.
In all seriousness, ask them how much and then decide. Taking heads off is alot more work than pulling the upper intake, and they do charge accordingly.
Old Feb 12, 2001 | 03:49 PM
oldblueZ's Avatar
Car: 85 Z28
wow, both message boards (here and camaroz28.com) say to leave the heads on and changing the springs and rocker arms would be better.
So I won't talk to them about porting the heads anymore. I will just get new valve seals, stronger springs, and the stamped 1.6 roller rockers from crane.
Thanks,
Jesse
LT1Formula
20
Nov 14, 2015 12:02 AM
hayesaw0210
Aug 23, 2015 11:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Jake_92RS
Aug 11, 2015 10:39 AM
