350 TPI intake on a Vortec?
Okay I have a vortec long block with everything ecept the intake and I want a TPI setup on it. Would the HP/Tq be estimated for a Stock 5.7 Vortec with the TPI intake on it??
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: 350 TPI intake on a Vortec?
Its hard to estimate power when you haven't given any information on the "Stock 5.7 Vortec" (year, vehicle, etc). Without knowing that, nobody knows the base power you are starting with.
If you do a search, you will find Vortec TPI information has been covered many, many times.
Best of luck.
Best of luck.
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I think the L31 engine developed either 265 or 285 hp in the pickup. I think it was 285.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
With the tiny cam in the Vortec trucks (about 194/198), I would say it would make about the same amount of power as a regular TPI engine. Put in a L98 or LT1 camshaft and you'd see about 20 more HP.
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
i have a 96 vortec stock engine with tpi on it and it has 305 hp at the crank when it was dynoed
1992rs/ss
Jan 31, 2025 05:10 PM
Sanjay
Aug 12, 2015 03:41 PM
