What type of injectors are these?
Old Aug 29, 2007 | 04:58 AM
The_Phoenix's Avatar
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Hows it goin? I just purchased a '89 GTA that came with a set of used 40lb injectors (so the owner says) but the strange thing is that they have the "ford" label on them! did the owner just me or can ford injectors actually be used on TPI engines? here are some pics! Thanks!
Old Aug 29, 2007 | 08:01 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: What type of injectors are these?
Yes, Ford injectors can be used in a TPI car. I have them in mine and so do many other people on here. Do a search and you will see.
Old Aug 29, 2007 | 09:07 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
36# Ford's here.
Old Aug 29, 2007 | 09:46 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Yes.
I'm very happy with mine.
Old Aug 29, 2007 | 10:39 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
That looks like the 22# Bosch injectors I have on my car.
Bill
Old Aug 29, 2007 | 11:18 AM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
be happy,that's a couple hundred dollars to do, to purchase i mean. 40# sounds wrong though
Old Aug 29, 2007 | 12:19 PM
88blackgta's Avatar
Car: 88 GTA Notchback
Engine: 355
Those injectors are manufactured by Bosch for Ford. They are sold by many suppliers as replacements for the Multecs. The "pink" Bosch's flow slightly less than 22lb/hr however on a stock L98, they will work fine as replacements. Do a search and you should find much more info about them.
Old Aug 29, 2007 | 01:20 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
30's in mine they work well, but are a little loud
Old Aug 29, 2007 | 10:43 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
heh, i have the lucas disk type injectors, can hear them from my drivers seat if the hood is open.. but they work pretty sweet for 20 yr old injectors..
Old Aug 30, 2007 | 01:29 AM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
LOL! and I thought they were performance injectors!
Old Aug 31, 2007 | 12:10 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
no such thing as performance injectors, your perception is skewed.
there are cheap injectors, and injectors worth the money, thats it, in my opinion.
now what you have are well regarded and widely used as replacements for performance minded enthusiasts, so in one respect, yes you have "performance" injectors. but all in all, they all squirt fuel, and how much they squirt for a given input is how they are rated (grossly simplified explanation).
as i said, be happy your looking at well over 300 dollars to do it yourself, and it's allready done. think of it kind of like,,a temperature sensor. you can pay full price at the dealership, or you can pay bargain bin for overseas parts, guess what they still read the temp,accurately for the most part. longevity might be the difference in price. get the idea? you're doing good and you didn't get raped by any means. 40's would have been rediculously oversized anyways.
Old Aug 31, 2007 | 11:39 PM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Right on! Nice lil' freebie that came with the car but wasn't sure what type they where; Now I won't have to look for a set of injectors if mine go bad! They seem to be in good condition...what do you guys think? also, which if the numbers on the injector represents the lb/hr if any?
Thanx!
Old Sep 1, 2007 | 01:38 AM
Shadow's Avatar
Car: 88 GTA Notchback WS6
Engine: 350 with a SuperRam
None of the part numbers on the injectors tell what lb/hr they are. On one side is the Bosch part number (0 280 150 561) and another is the Ford part number (FOTE-9F593-D9B). There will also be a three digit number which is a date code when they were manufactured.
Old Sep 1, 2007 | 06:34 PM
Drac0nic's Avatar
22lb/hr http://users.erols.com/srweiss/tableifc.htm
Old Sep 2, 2007 | 12:06 AM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
my injectors read: 280 150 945 on one side; the other side reads: f1se-e5a. there are 2 3-digit codes on mine: 927 and 282.
Old Sep 27, 2007 | 06:07 AM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
LOL! never got a clear answer....so these injectors are 22lb/hr??
Old Oct 5, 2007 | 04:01 AM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Anyone??
Old Oct 5, 2007 | 01:38 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
sorry i cant help you with that one.
Old Oct 5, 2007 | 02:46 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
you have Pink tops which are rated at 22lb/hr.
Old Oct 5, 2007 | 09:09 PM
jbpnumber03's Avatar
yes, they are 22lb/hr injectors. i bought a set of these a few years ago for my car. i put about 20,000 miles or so on them and I just took them out and put in 30#/hr with my new heads, cam, headers, y-pipe, and runners so if anyone wants a set of these injectors ive got a set for sale.
Old Oct 6, 2007 | 06:00 AM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Cool! Speaking of injectors, what is the lb/hr rating on stock injectors?
Old Oct 6, 2007 | 07:02 AM
battman's Avatar
22lb/hr
Old Nov 4, 2007 | 01:46 AM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Whoa! check this out! I was about to install the red tops on my '89 GTA but decided to do a little research to be sure of the flow rate and found that they are actaully 30lb injectors and not 22lb ones...good thing I found this out otherwise my car would of been running rich like crazy! check out the link http://www.fiveomotorsport.com/Injec...RD.asp#bluetop you can't miss em!
hope this info helps!
L8R!
Twin_Turbo
Mar 14, 2016 10:10 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Hello, Michael
Sep 11, 2015 01:10 PM
92rsvortec350
Sep 10, 2015 10:54 AM
