Will 52mm throttle body work on L98?
I have a 90 corvette with the L98 6spd. i have already ported the stock intake base and opened up the exhaust,k+n,hotter ignition,1.6roller rockers,and custom prom. my question is will a 52mm throttle body help out any? I already have a new one on the shelf and i'm trying to decide whether to install it or sell it. thanks for the help.
[This message has been edited by WINNER (edited March 02, 2001).]
You didn't say whether you've ported the plenum yet. You won't get the full flow of the 48 or 52 mm TBs until you grind down the EGR bump just behind the plenum entry holes, so do that first if you haven't already. I'd also open up the entry holes to 52 mm if you decide to go that route. I've already done this to my plenum even though I still run the stock TB. That way, it's a simple remove and replace when I step up to the 52.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you already have one, go for it. But if you were looking to buy one, I'd say with your current mods, no.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
I don't think you need a 52mm throttle body until you are above 300 rwhp. Plenty of LT1 cars make that with the same size throttle body. I'm going to do a heads/cam/exhaust (intake possible) swap and see how it runs before I consider a bigger TB.
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Terrell351
Jun 13, 2021 01:13 PM
